SOURCE: hitachi cle-990
not sure your model number is correct please check here is a manual for the 42 CL plasma TV http://www.hitachiserviceeu.com/scripts/userguide.php/CL42PD2100_EN.pdf if it is a different set please check the model number, this should have a 42 in it (as it is 42")
SOURCE: hitachi remote CLE-967
Hi.
I wrote an article on how to repair remote controls.
You will find it here.
http://www.ehow.com/how_2094701_tvvcrcabledvd-remote-control-quick-easy.html
Chris.
SOURCE: tuneing in my tv
Hi There
Came to this site with the same problem - finding no answers I went back and tried again
Hope this isn't too late for you. Press the 'MENU' button - you'll get the picture sound etc - keep your finger on it and you get 'INSTALLATION' at the bottom in white!
Hey presto! use the <&> to get into the sub menu and away you go!
Hope this was some help
(P.S. use the menu button on the front of the set if the remote button fails to bring up the installation option = it is behind a flap between the on/off button and the indicator lamp under the screen)
SOURCE: manual tuning of Hitachi cle-942 tv
Select the channel to tune & press "CH" this is the key to the right of zero on the CLE-942 remote, Now you can tune the selected channel. You also need this key to sort/move channels after running auto tune.
SOURCE: I have a remote to a hitachi 42 inch plasma TV
You can check on ebay for this. They have many different options. You can also get a universal remote for the TV. If you buy one that learns, you can use a remote from Best Buy or somewhere that has the remote you are looking for.
http://www.42televisions.net
