tail lights , brake lights , indicators all work through the fuses for the vehicle applications
check the wiring of the vehicle plug and trailer plug as they have a habit of filling with water and corroding the wires off
it he vehicle taillights ( as an example )work but not the trailer lights , it is not a fuse but a harness connection probably at the plug
If it's loose from the door, you need to remove the inner door panel to access the screws that hold the mirror in place on the door itself. To remove the inner door panel may simply involve removing some screws, but some models require a special upholstery tool to loosen the panel fron the clips. Once the panel is loose, tighten the mirror and replace the inner panel. Be cautious with door switch wiring!
Take the liftgate inside panel off an check the wiring , connections etc.... rear door hatch lock repair GMC Chevrolet chevy tahoe lift gate not opening
The liftgate will lock any time the vehicle is shifted out of park on vehicles equipped with an automatic transmission and at vehicle speeds exceeding 5 kph with manual transmission. This happens in conjunction with auto door locks if enabled or independently of auto door locks if the feature is disabled. This ensures that the liftgate is locked anytime the vehicle is shifted out of park or when the vehicle is in motion.
The liftgate lock relay supply and coil sides receive a constant voltage through the battery voltage supply circuit and the ECC fuse. The normally closed contact is connected to ground and the control side is connected to the body control module (BCM). A lock function will occur when a door lock switch activation, keyless entry lock transmission, auto door lock function or a liftgate lock function has been received by the BCM. The BCM will then ground the control side of the liftgate lock relay. This energizes the relay and allows voltage to be applied to the liftgate lock actuator lock control circuit. Since the other side of the liftgate lock actuator is connected to the normally closed contacts of the door unlock relay to ground, the liftgate will lock. When an unlock function occurs the BCM will ground the control side of the unlock relay and the rear doors and liftgate will unlock.
The BCM also runs diagnostics on the liftgate lock relay control circuit and will set DTC B3825 as current and also send a Class 2 message to the DIC. The DIC will display REPLACE LIFTGATE FUSE to inform the driver that a fault has been detected in the liftgate lock circuit and that the liftgate is not locked. Faults that will set the DTC and cause the DIC to display the message could be any of the following
Power Door Locks Inoperative - Endgate/Liftgate
Schematic Reference: Door Lock/Indicator Schematics
Connector End View Reference: Power Door Systems Connector End Views
Did you perform the Diagnostic System Check - Vehicle?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Vehicle in Vehicle DTC Information
Activate the door lock switches to the lock and unlock positions.
Do both rear passenger doors lock and unlock?
YES - Go to Step 3
NO - Go to Power Door Locks Inoperative
Did the liftgate lock actuator lock and unlock?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 4
Disconnect liftgate door lock actuator.
With a test lamp connected to a good ground, probe the door lock actuator lock circuit at the door lock actuator harness connector.
Activate a door lock switch to lock position.
Does the test lamp illuminate?
YES - Go to Step 5
NO - Go to Step 7
5
With a test lamp connected to a good ground, probe the door lock actuator unlock circuit at the door lock actuator harness connector.
Activate a door lock switch to unlock position.
YES - Go to Step 6
NO - Go to Step 8
6
Inspect for poor connections at the harness connector of the door lock actuator. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 10
NO .. Go to Step 9
7
Repair the open door lock actuator lock circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 10
8
Repair the open in the door lock actuator unlock circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 10
9
Replace the liftgate door lock actuator. Refer to Door Lock Actuator Replacement in Body Rear End.
Did you complete the repair?
Go to Step 10
10
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
There is no way but to short the wires at the tail door switch outside which should only be done if you have a circuit diagram and experience on the vehicles electrical systems or you could damage components beyond repair.Make sure the fuse is not blown.
