Most likely is is seized due to lack of regular oiling. If this is the case, AVOID trying to run the motor until the issue is addressed or the motor may be damaged.
Wheel on right side that controls the needle up and down is very tight...
SOURCE: PFAFF 1222E Sewing Machine (~1977). Mechanically Locked-up
You might be in "Stopmatic" mode. Check if your pressure lifter bar is in the upper most position, if it is the machine is disengage and you are set to wind your bobbin. Lower it to the 3 o-clock position this will engage the machine and the needle will operate.
SOURCE: Cannot turn the balance wheel - new machine to me.
You have to lower the presser foot by one click to release it from bobbin winding mode. This mode is the same as needle down while presser foot is up so you can turn your work when it needs to go a different direction.
SOURCE: I have a Pfaff 1222E sewing machine which needs a new motor
Good for you, to repair a great machine instead of buying some more modern, disposable machine!
I found a generic motor that will fit your machine at http://www.pfaffmachines.co.uk/partsDB/index.php?function=detail&recordID=185. Free delivery within the UK, but that doesn't help much, does it?
There's several places in the U.S., like http://www.a1sewingmachine.com/parts.html
http://www.sew4less.com/QuickSearch.php
http://sewingpartsonline.com/
You'll probably need to look for a generic motor for your Pfaff, but they should be out there.
I did check eBay; they do have generic sewing machine motors, but unless you're very experienced with eBay, I'd be very careful there.
Check with your local sewing machine dealer/repair place (even if they don't carry Pfaffs). Maybe they can help.
Good luck--I wish I could be more helpful, but let me know if anything I've sent helps, ok?
Robbie
SOURCE: where are the oil holes
There are no oil holes in a 1222e. I apply a light oil to the inside of the bobbin case and where you clip the bobbin in the machine. I also take off the top and drop a light oil on the moving shaft. I was told no other lubrication was needed by the owner.
