Cell Phones Logo
A
Anonymous Posted on Jul 14, 2017
My iphone 5c wont connect it is stuck on searching
Marvin
Level 3:
Top Expert:
  • iPhone 5c Master 85,242 Answers
  • Posted on Jul 15, 2017
Marvin
iPhone 5c Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29058562
Points
266281
2 Related Answers
chris watts
  • 13 Answers
  • Posted on Dec 11, 2013
SOURCE: Is there adaptor for iphone 4 jack to use with iphone 5c lightning jack
On eBay there is an adaptor to connect iPhone 4's and iPods to iPhone 5.
Terry Corrow
johnny rebel
  • 10875 Answers
  • Posted on Jun 21, 2015
SOURCE: Hi my iPhone 5c is just saying searching after changing the screen please help
the antenna was unhooked,now to take it apart again.....
Loose contact and contact information after entering a new contact on iPhone 6
As for your situation, you can recover the lost contact on iPhone with iOS Data Recovery. Just follow the below steps to do that.
Step 1 Connect your iPhone 5c to the computer
So as to recover deleted contacts on iPhone 5c, you should free download Leawo iOS Data Recovery on your computer first, and run it on the computer, and then use a USB cable to connect your iPhone 5c to the PC.
Step 2 Start to scan your iPhone 5c
Once your device has been detected by the iPhone 5c contacts recovery program, a "Start" interface will show, just click "Start" to scan your iPhone 5c.
Step 3 Preview and choose contacts on iPhone 5c
The scanning will only last for several minutes, after scanning, you are able to see all the different types of files listed in neat categories on the left sidebar. By clicking "Only display the deleted items" option on the left corner of the interface, you'll see all the files that have been deleted from your iPhone 5c. Just click "Contacts" type to preview and then tick the single contacts you want to recover from iPhone 5c.
Step 4 Recover deleted contacts on iPhone 5c
After preview and selecting files, tap on "Recover" button on the right corner, then you'll see a pop-up window for you to choose saving location for the files. Click "Open" to browse the computer file explorer and choose a saving folder on your PC, then click "Go" to start to recover contacts from iPhone 5c.
This is just an example to show you how to recover deleted contacts from iPhone XS Max and other iPhone models directly. Actually, Leawo iOS Data Recovery could help you recover deleted contacts from iTunes, and retrieve contacts from iCloud as well.
For more methods, check: How to Recover Contacts from iPhone
Aug 15, 2017 • Cell Phones
My iphone 5c wont do anything only a blank screen wont switch on
If the battery is good and you have verified that then the phone is most likely defective. Batteries are cheap try replacing it and performing a factory reset.
My Iphone 5c wont charge it's dead
replace the battery the new one , check adapter voltage its okay or not, check the charging cable, if you using oe cable maybe wont charge
I have an 8GB SDHC with private information on it. How do I put it on my iPhone 5c
the iphone 5c doesn't support the SD cards. if you wont to transforme data from your SD card to your Iphone you have to use a PC and the "itunes" it's simple.
My iphone 5c won't connect to a mobile network
Verify that phone connects to network that it was originally designed for.
Iphone 5c won't connect to internet after upgrade. Google works fine
If Google (search?) is working, then you ARE connected to the internet. Specifically, what isn't working?
Iphone 5c wont charge but
This could be for a number of reasons. You adapter, plug, or cable might be bad, or if your iphone got wet or was dropped that could be the case. If wet, you should get a new phone.
1helpful
2answers
My DVDXCOPY Platinum will not activate after inputing the License ID# and Password. Can anyone help please?
DVDXCOPY has been shut down for many years, their are a few people still selling it knowing it can't be activated. Their were a few sites that carried activation codes that worked. In all reality its not a very good program, I started out using it and switched to DVDFAB Platinum and haven't found anything it wouldn't copy, it also shrinks long movies to fit on a 4.7 DVD.
Top iPhone 5c Cell Phones Experts
john h
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you an iPhone 5c Cell Phone Expert? Answer questions, earn points and help others
