To do a full factory restore wiping everything ..
Turn on the computer, after the Dell logo press F8 key repeatedly until the
Advanced Boot Options menu (Advanced Startup Options).
In Advanced Boot Options, highlight Repair Your Computer and press Enter.
Click Next and logon to the administrator account in the computer.
Click Dell DataSafe Restore and Emergency Backup and DataSafe Options.
Choose Restore without preserving new or changed file. Click Next to continue.
Choose Yes and click Next to continue.
Progress status will appear. Click Restart to initiate the restoration process.
The link I attached may give you some further help.
Good luck & have a great day! :)
Can you reset DELL Inspirion to factory settings on windows 7 with the...
SOURCE: I need to set the camcorder to default settings
For most models, removing the battery pack from the camcorder will restore the default settings; however, some models which contain an EZ Q button, store your settings and removing the battery pack will have no impact on these settings. The Lithium battery maintains the clock function and preset contents of the memory; even if the Battery pack or AC Power adapter is removed. Removing the Lithium Battery along with the Battery pack will restore the default settings.
SOURCE: Restore factory Settings on a Dell Inspiron
hi..
if you have windows xp then you need to turn your computer as soon as you do that before you see the windows xp logo hold down the control key and keep tapping f11 key.it should take you to the screen fro factory settings and if it is windows vista then you can go ahead and press f8 and then choose repair my computer,hit enter which will then prompt you to login in once you log in it will tell you to choose the options from the options listed below choose the one which says restore factory default...you computer will be restored to factory settings..
vedhick
SOURCE: Need to reset back to factory default
hello I am using PANASONIC KX-T308 , and forgot its pasword. I want to reset its password back to factory default i.e. 1234. can some one help me ?
SOURCE: restore Dell Inspiron M5040 to factory settings
Resetting
a Dell Inspiron to the factory settings allows the user to restore the
Dell Inspiron to the original operating condition as if it was just
taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Step 1:
Before reset any Dell Inspiron laptop, backup your all important data
and programs, otherwise you may lose it. It is recommended to use an
external storage device for your entire data backup, so that you couldn't lose it in any sudden occurring issue...
Step 2: Remove any other unnecessary external drive and restart your Dell Inspiron laptop.
Step 3: Press 'F8' key continue until 'Advanced Boot Options' wouldn't be appear.
Step 4: Use your keyboard arrow key to select 'Repair Your Computer' from the list and hit 'Enter'.
Step 5: Now click 'Next' and login as the administrator account.
Step 6: Click 'Dell Factory Image Recovery and Data Safe options', select your language option and click 'Next'.
Step 7: Click the check box 'Yes, reformat hard drive and restore system software to factory condition' and click 'Next' to start Dell Inspiron reset process...
This
process will erase all your previous changes that have been made to the
Dell Inspiron laptop and reset the configuration settings to factory
setting.
Feel free to get technical assistance for all type of Dell laptop at http://www.vtechsquad.com/dell-support/
