SOURCE: fridge freezer not working after power cut
if its a ge i would say itsyour main board not compressor boards about 200
SOURCE: Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
SOURCE: Hello, The Freezer is a FZ150
flashing red light indicates it's too warm in the freezer.Check
the compressor to make sure it is running? if it is then your low on
freon.Check if fan near the compressor is running?If still the problem persist switch off the freezer for 24 hours and check for it is fully defrosted.This warm in freezer occurs due to block in air flow due to defrost of ice.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Testimonial: "Hi Roy, I tried that for a few days, no change. Hotpoint recommend it is set at 3 or 4 (options 1-5) I put in a tray of water in the ice cube tray and it froze ok, just took a little longer. I'm pretty handy at DIY and most things, is fitting a new thermostat a tricky job, I generally try all DIY and repairs myself before I'll call in an expert. Appreciate your feedback."
