Question about Kyocera Office Equipment & Supplies
Whats the cause of call service C7900 for KYOCERA TASKALFA GX 2200?
Posted by Sticky on
kagimu joseph
    Habit-Forming:
    Scholar:
  • 109 Answers
Drum EEPROM error Reading from or writing to EEPROM cannot be performed.
Causes
Poor contact in the connector terminals. Defective drum unit.
CHANGE THE DRUM HOUSING
Posted on Nov 16, 2017
5 Related Answers
Sheri McMichael
  • 241 Answers
SOURCE: Kyocera FS-3900DN Ecosys Call Service 2200:0100998
The Call Service 2200 is a drum motor error. The motor or gears might need to be replaced. First remove and re-seat both the developer and the drum unit. The developer is directly under the toner cartridge - lift it up then out first, then open left side door remove the waste bin and press the button on the drum unit just above the waste bin pull the unit out (carefull not to touch the drum surface). Re-seat both units. If this does not work call in a Kyocera Tech.
Posted on Jun 09, 2010
saidisaid708
SOURCE: i also need a service
call service c3100
Posted on Nov 09, 2010
sodeep
Sudeep Chatterjee
  • 3267 Answers
SOURCE: installing a new kyocera TASKalfa 250ci and i got
C3100 Scanner carriage problem
• The home position is not correct when the power is turned on or copying the document placed on the contact glass.
Poor contact of the connector terminals.
Defective scanner home position switch.
Defective engine PCB.
Defective scanner motor.
This copier may need a service adjustment. The problem could be something as simple as a switch not being in home position. Please troubleshoot accordingly. Unplug device when troubleshooting.You should also troubleshoot it by looking to see if anything is blocking or stuck causing the carriage to not go into position.
Posted on Dec 22, 2010
shawn38
Shawn
  • 200 Answers
SOURCE: my kyocera taskalfa 180 showing
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Posted on Mar 02, 2011
ASHIQ
SOURCE: Free service manual with code
To reset -
C-TECH INFOWAYS
Posted on Nov 19, 2011
Kyocera Taskalfa 1800 monochrome Multi Function Laser Printer how solved call service c7900
empty the waste toner from the drum unit small removable covers on both sides
Mar 20, 2018 | Kyocera Office Equipment & Supplies
Keyocera taskalf 1800 photo state black& whit printer how solved call sevice c7900
Place a telephone call to your Kyocera equipment servicer and mention code c7900.
KYOCERA TASKALFA GX 2200 is displaying call service C7900, how can i fix?
Drum or Dv can cause it if they are not seated correctly. or the board that the drum or dv is connect too. might be bad cable or is not connected.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Jul 14, 2017 | Kyocera Office Equipment & Supplies
Kyocera taskalfa 1800 call service c7900
Kyocera-Mita TASKalfa 1800 Error Code: 7900DescriptionDrum EEPROM error
No response is issued from the device in reading/writing for 5 ms or more and this problem is repeated five times successively.
CausesDR PWB. Main/Engine PWB.
http://printcopy.info/?l=en&mod=erc&brand=Kyocera-Mita&model=TASKalfa 1800&code=7900
Aug 08, 2016 | Kyocera Office Equipment & Supplies
Kyocera taskalfa 300ci
10871087 to enter service mode. There are 2 maint. kits for the 300ci. One for color and one for mono. If you were able to perform a maintenance then you should be well versed on which adjustments to make and which counters to reset. If not you can cause major problems so be careful.
Dec 16, 2013 | Kyocera Office Equipment & Supplies
My new kyocera taskalfa 181 copier diplay call service c3100
please unlock the 2 scanner lock on top left side of the machine. the lock will be in yellow colour and it will covered by red tape.
Sep 20, 2012 | Copystar Kyocera Taskalfa 181 Copier
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
491 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
