SOURCE: nec lt81 dlp projector
I just noticed that the power light will light orange and the status
light blink red if any of the external dust filters are not in place.
There are little switches that tell the projo if they are missing. So,
double check that the filters are in correctly.
Is the fan running properly or are any vents blocked?
Sounds like it is overheating.
Might just be that the thermal cutout is going bad inside the unit. Shutting off at to low a temperature.
Sounds like the most likely cause. They do change properities as they get older.
Goodluck..
SOURCE: Carrier Furnace Model 58STA/STX not firing
Have you checked the gas valve on the unit.. is it set to on? also check the gas valve going to the unit on?
SOURCE: We also have a Vizio with red horizontal lines and our TV is new
It's possible that the motherboard or the controller board for the screen is defective. At this point, I would use the warranty from Vizio. It should be no doubt that it covered. Here's the info you will need from the Vizio web site.
http://www.vizio.com/support.aspx?id=1588
SOURCE: Digital temperature display is missing part of the
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Testimonial: "Thank you for the quick response!!!!"
I highly recommend you to get a USA Prime Aquarium Chiller you
wouldn't be disappointed. You can also get chillers from Aqua Logic Aquarium Chillers, Deltec Eco Cooler Aquarium Chiller, Coolworks
- IceProbe Aquarium Chiller, Oceanic Aquarium Chiller, TECO SeaChill Chillers
and Tunze Aquarium Chiller the all solid chillers companies.
