Model # 074359
SOURCE: breeze ceiling fan not working
We have a 52" Aloha Breeze fan that stopped working this evening - fan and light. The remote control was burning up - after reading the other posts I hate to see what else is burning! Sounds like it would be safer to buy a new, reputable fan than spend more money on replacement parts.
SOURCE: installation of wall remote for harbor breeze ceiling fans
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
SOURCE: can't find codes for my hampton bay universal remote
i need the codes for my hampton universal remote control
needed for my Quasar tv combo
SOURCE: Remote fans quit working during a thunderstorm-lots of lightning
I've been having the same problem with my remote not working. I actually just checked the dipswitches in the remote against the ones in the ceiling fan, and they somehow were not the same. It seems that the 4th dipswitch may have inadvertently been altered due to the battery either being changed or just moving. I advise you all check out the settings on the actual fan to see whether or not they match up.
Twist the cap covering the wiring above the fan (make sure the power is off, just in case), and you will see a black box like thing straddled towards the top. There is a little rubber square cap guarding the dipswitches. Take that off and note the setting of the 4 switches (on/off). Compare it with the remote by taking the batter pack off and looking at the 4 switches there.
I noticed that the 4th switch on my remote was turned on when it should have been off. I changed it back, and now it works.
Hopefully this helps you all.
