If all else fails, I recommend contacting a local car audio professional, or you may contact Clarion customer support directly by clicking here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information has proven beneficial.
SOURCE: Clarion CDC1235 CD Changer
hi Its Error 6 no focus. could be dirty cds. dirty laser. or faulty laser. regards Mark www.carradiospares.co.uk
SOURCE: My clarion vrx935vD doesn't come out.
simple thats because you must have forgot to plug the small adapter in the back of the deck that has a yellow and black wire coming from it. if you have then one of those two wires are not hooked up to the right place. and if that fails then either u have a bad connection somewhere in ur car wire or in the inside of ur deck. i had the same problem when i hooked up mine i just forgot to hook up that adapter because its really small
SOURCE: 1992 SAAB 900. Clarion radio. After repairs to
Are you sure that 1112 is the correct code as it looks as though your radio is not accepting it.
To check, post the radio MODEL NUMBER (begins with PU ) and also ALL the LETTERS+NUMBERS on any labels, barcodes or stamped in the casing and I will be able to see if I can check the code.
SOURCE: i need the diagram for a clarion touch screen cd
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
SOURCE: clarion vrx 485 vd.tuner works with amp but cant
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
it sounds like you have hooked the power wires up wrong try trace back your wires with this diagram
