Question about Whirlpool Cooktops
How does the back come off whirlpool hob model G2P 61F/01SR/WH
Posted by Margaret freedman on
Glass on neff t4243 induction hob has cracked
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
Feb 28, 2012 | Cooktops
My soup spilled over on to my whirlpool ceran cooktop and i cant get the stains off. Is there a way to do it?
Is this a ceramic hob? If it is, you will need a ceramic hob cleaner (john lewis does one) OR Astonish oven/pan cleaner, a non-scratch washing-up sponge and a fair amount of elbow grease. This works for me.
Oct 05, 2009 | Whirlpool RCS3014 Electric Cooktop
I have a neff T1.D20 dual circuit hotplate but although the inner lights up and gets hot the outer part doesnt. Is the outer part supposed to?
I have a T172 model which also has a dual circuit hotplate.
In the control area you should find a dual circuit control pad - this has two concentric circles on it. With the hob switched on, pressing this button will chnage the mode of the dual circuit hot plate bewteen:
1. Just the inner part
2. Both the inner and outer together.
When the hob is switched off using the Standby control pad, it remembers which mode was selected and will therefore work the same next time it is switched on. However, it is worth noteing that when the mains power to the hob is interuppted, either by an isolator switch/breaker, or a power cut, the hob defaults back to just the inner ring mode.
Oct 03, 2009 | Neff T1323 Electric Cooktop
Gas doesn't come through to hob
hi,mostly is the problem is in only the line,i think ur line is far in ur cooktop thats why is the gas flow is slow to out in ur cooktop try & try,open ur gas valve for about 3 min or more until the gas is out.
Sep 03, 2009 | Whirlpool GLT3014 Gas Cooktop
Electrolux insight cooker EKT6045 problem with hob controls
i have an electrolux model ekt 6045 it does not stay on it comes on for 1sec then goes off wot would be the cours of this please the oven stays on but the hob doesent thank you.
Aug 11, 2009 | Electrolux Cooktops
Horribe stains left on whirlpool gas hob by domestic cleaner
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff will do the job!!
Jul 04, 2009 | Thermador PSC364GDZS Gas Cooktop
TOUCH CONTROL HOB (SCHOTT CERAM) GLASS CRACKED
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Vic
May 18, 2009 | Cooktops
Cillit bang damage to stainless steel hob
I left cillit bang on my Whirlpool stainless steel hob. It left a real mess and looked ruined, however I have a solution. You need Astonish cream cleaner, I got mine from the Kleeneasy catalogue, just get a damp cloth and rub gently all over. You might need to do it a few times, wipe it clean with kitchen roll then rub some oil (I used olive but baby oil is good) and it should buff up to a really good finish.
Mar 19, 2009 | Cooktops
Flame on gas hob not correct.
I'm not sure what you mean by a proper efficient flame. I just recently went through an experience I'll relate to you here. I purchased a GE Profile dual fuel range. I can get more specific if you'd like but here's the point. The highest burner on the range was rated at 17000 BTU's. A friend recommended the range to me and sang it's praises. I took delivery of my new toy and couldn't wait to get a pot on the stove to start cooking a long wait for pasta. Twenty minutes later I was finally seeing bubbles! I spilled the water out and measured 12 cups of water into the pasta pot at room temperature. That's three quarts of water. 20 minutes to see bubbles and never would it come to the expected "rolling boil". My experience has always been with electric ranges and I am new to gas but 20 minutes? Something had to be wrong, right? Wrong! Much research later I've found it is common for natural gas to LP conversion stoves to lose a good deal of their oumph when converted. GE as it turns out is one of the most notorious for a serious degredation in BTU output. After exploring GE's site I found that this same stove running under LP gas is rated(for the highest burner) at 11000 BTU's! No wonder I couldn't boil water! Back to the store it went and I am still in search of a stove that will meet my needs. Don't know if this will help you or if this is the same issue you are dealing with but maybe just maybe. Good luck!
Apr 29, 2008 | Cooktops
Cooktops Logo
181 people viewed this question
Top Whirlpool Cooktops Experts
Michael Thomas
Michael Thomas
Gustavo Ortiz
Gustavo Ortiz
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
