SOURCE: language setting on olympus E-510
http://www.digitalcamerainfo.com/content/Olympus-EVOLT-E-510-Digital-Camera-Review-14157/Design--Layout.htm
SOURCE: Changing Language
I had the same problem with my Canon Smartbase MP730. Printer
properties was in Portuguese, no matter how many times the driver was
uninstalled and reinstalled.
By running Filemon from SysInternals I realized that when showing the printer properties files in the
C:\BJPrinter\CNMWINDOWS\Canon MP730 Printer\LanguageModules\0409\
folder were created. One of those files was CNMmhya.hlp. When clicking
on it a Help-window with Portuguese text shows up - even though the
code 0409 means English. This is a symptom of the problem. This file
was copied from somewhere in the Windows folder.
To fix this annoying problem, the following worked for me:
-> Unplug the printer
-> Uninstall the driver
-> Rename the following folder with the portuguese language driver
stuff which still remains, even after uninstallation of the driver:
C:\WINDOWS\system32\spool\drivers\w32x86\3
(if you cannot rename it, reboot and try again). You should first check
that there are indeed portuguese help-files in this folder. To do that,
click on one of the .hlp files. If they are not your problem could be a
different one, but it could also be that the files are stored nearby in
the file system.
-> Reinstall the driver with the language of your choice. This time
there won't be Portuguese files blocking proper installation of your
new files.
-> Replug the printer to finish the driver installation
Now you should have finally gotten rid of the Portuguese (which may
seem Spanish or Italian to some) text in Printer related windows.
SOURCE: i can't transfer the images from my olympus master
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
SOURCE: CHANGE LANGUAGE SETTIGS
1.
Click Start, and then click Control Panel.
2.
Click Date, Time, Language, and Regional Options.
3.
Click Add other languages.
4.
In the Regional and Language Options dialog box, on the Languages tab, click Details.
5.
In the Text Services and Input Languages dialog box, on the Settings tab, click Add.
6.
In the Add Input Language dialog box, click the Input language list and select your preferred language and dialect. If you want to change the standard keyboard layout, click the Keyboard layout/IME list and select a new keyboard layout. Then, click OK.
7.
In the Text Services and Input Languages dialog box, on the Settings tab, click the Default input language
list, and select the language you will use most often. The language you
select as the default will display when you first start your computer.
8.
To add additional languages, go back to step 5.
- or -
If you have finished adding languages, click OK.
9.
In the Regional and Language Options dialog box, if required, select the Install files for complex script and right-to-left languages and Install files for East Asian languages check boxes.
10.
Click the Regional Options tab. Click the Standards and formats list, and then select your region.
11.
Click the Location list, and then select your location
12.
Click OK to save your settings.
Top of page
Click Here for more info
SOURCE: need to change language for spanish to english
just go to teh site mobile heart.com and download the software for any language
