Question about Samsung Refrigerators
Rf267aers samsung french door refrigerator. Ice crystal build up on items in freezer and freezer light not working. any thoughts?
Posted by dave lovick on
5 Related Answers
Anonymous
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
Anonymous
SOURCE: samsung refrigerator
There is a screw down foot in front of each forward wheel under the fridge. You can access this by looking under the front corners.
Posted on Apr 16, 2008
TheRepairGur
Chris Z
  • 27 Answers
SOURCE: I have a kenmore three door refrigerator ice crystal built
This is usually due to an air leak at the freezer door/drawer. Check out the gasket and if it is bad, out of place replace it. If the gasket looks good go around the door with a dollar bill closing the bill in the door. The dollar bill should resist being pulled out. If you find spots where the bill slips out easily this is a spot where the door/drawer is not sealing good and letting in air causing the frosting.
Go here for: Kenmore-Refrigerator-Parts
RepairClinic.com
Appliance parts, help & more
Posted on Apr 29, 2009
SOURCE: Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
Posted on May 07, 2009
Avi
  • 66 Answers
SOURCE: Ice build up on floor of freezer drawer starting under ice maker
since this problem is discussed over and over on various models, I point you to a detailed manual that shows (with images) how to solve the frozen drain pipe issue. This is the manual by Avi
good luck
Posted on Jan 29, 2011
Ice buildup in bottom of freezer compartment
Here's a link to a great website that will help you understand what might be causing your freezer to have that ice build up. I could explain it here, but if you look at this link, they've already done a wonderful job.
http://www.appliance411.com/faq/defrostproblem.shtml
Jun 08, 2016 | Samsung RF4287HARS French Door...
We have ice sheets forming under cool select pantry drawer of our refrigerator. What should we do?
the fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature. May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Feb 12, 2015 | Samsung RF267AERS French Door Refrigerator
Samsung RF4267HABP ice build up
Is the ice build-up in the freezer section, or in the chill section ?
Mar 17, 2014 | Samsung RF4287HABP Refrigeration :...
Ice buildup in frig above evap coils. Defrost coils seem to work, at least on manual. Samsung mdl RF266AES/XAA
If the defrost element is working the you have to totally defrost the evaporator, kick it back into life & all should be ok. Air intruding into freezer could be the cause of the frost, make shure the seals are ok & in place, make sure the doors are closing all the way.
Nov 20, 2013 | Samsung RF267AERS French Door Refrigerator
Samsung rf267aers won't make ice
26 cu ft French Door Refrigerator Here is a refined site that has a variety of sensible answers for your product. This will save a service call and you can even obtain live support. Good Luck.
Dec 29, 2012 | Samsung RF267AERS French Door Refrigerator
Ice build up in freezer and temp in fridge section not very cold
just needs to be defrosted ice is blocking the vent for the bottom defrost it and should be good
Aug 28, 2009 | Samsung RF265AA Bottom Freezer French Door...
Refrigerators Logo
55 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
