SOURCE: to set the clock on a jensen cd 2010x cd in car player
1. Press DISP for approx. 3 seconds until you see the clock flashing. 2. Use the up and down to change the values and the right and left (<< >>) to change from hours to minutes. Then hit the Disp to exit.
SOURCE: Jensens VM 9312 car DVD player problem
Just go to the set up menu ( Your screen should say setup at the upper center of your screen ) Then press 5, 4, 3, 2, 1, 0 with your remote control and a second menu will apear, on your left side press the second option and select parking bypass to on.
SOURCE: 6 disk cd player error
This is a part failure in the mechanism that loads and ejects the disk, there are no repair manuals avail to either the tech or the consumer, the only place that the factory gives this info and parts to are factory authorized repair stations, bottom line you must pull the deck and contact a Ford dealer in your area for location of the nearest factory repair station. I was dealer tech for 20 years and that is how it is done.
