What can I do to fix error 5B00 in Cannon 280 printer
The reason behind the canon printer error 5b00 is when the system continuously fills the ink tank and the printer stops to absorb that and hence we come to face this error.
Here are few steps which will help you in fixing canon printer error 5b00:
1.Reset The Waste Ink System Count First: the first method to solve this error is to reset the waste ink. By applying this method you can get out of the error which is troubling you.
2. Manually clean the Waste Ink Foam: to clean the waste foam you have to open the front cover of the printer. Now you have to remove the cartridges one by one and then clean the rollers. Now check whether your error is gone or not.
So, these are the steps to solve the error. If you found the error is still there, then you have to visit an expert.
SOURCE: canon printer displays error
CANON
PIXMA MP450
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will turn off printer.
2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
3. you will let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
6. you will turn off printer by button POWER.
SOURCE: waste ink tank full error 5b00
Check out:
http://www.fixyourownprinter.com/forums/inkjet/50418#1
SOURCE: WHAT IS ERROR 5600?
5600 is Hardware Error.Sounds like the printer have problem in logic board assembly.
SOURCE: I have a Canon Pixma MX320 and get the error code
Try this
1. Turn off your printer
2. Press and hold the
STOP/RESET button
3. Press and hold Power ON button
4. While
holding the Power ON button, release the STOP/RESET button
5. While
holding still the Power ON button, press twice the STOP/RESET button
6.
Release the Power ON button
7. Wait until it display an "idle"
message. It will take about a minute.
8. When "idle" appear, open
the top cover to expose the cartridges.
9. Lift up the cover for
cartridge holder and take out both the black and color cartridges
10.
Return the cover of cartridge holder and turn off the printer
11.
Return the top cover and turn on the printer again
12. After the
printer initialize, return the cartridges.
1. Press and Hold the
STOP/RESET button and wait until it self restart.
2. Release the
STOP/RESET button the the printer is restarting.
3. Wait for a few
seconds
