Question about Motorola Radio Communications
Motorola t5710: radios are set to the same settings and will not talk to each other...Is there a way to reset them to factory or default?
I understand these are older but I cant just go buy new ones. Both radios work on their own, meaning each one can ring and talk just not to each other. I have searched the web with no working answer yet. THANKS AnyONE
Posted by Stew Salyer on
eradiostore
  • Motorola Master
  • 1,658 Answers
Take the radios back to a very basic setting with all special features turned off. If the radios have a Qt filter check to see it is turned off, and set your Code to zero (off) on both units. Also, check to see your battery is good in both units. Trade the battery with a known good radio to see if the problem moves to the other radio, is a simple test.
Posted on Sep 10, 2017
5 Related Answers
SOURCE: cect i9 passwords
all the phones have a default password from the company.for e.g nokia has the default password as 12345. you can find the code by referring to your instruction manual.thanks for using fixya!. please dont forget to rate my solution.
Posted on May 28, 2009
siva subrahmaniam
  • 239 Answers
SOURCE: reset s3310 to factory default settings
*2767*3855# is the master reset code and "if" it asks for password type *#9072641*# ..
if it works or not works mail me at [email protected]..
therefore i can work with more..
i hope,it solves your problem..
"rate solution"
Posted on Apr 17, 2010
Anonymous
  • 103 Answers
SOURCE: We have a Lexmark X342n All in one device. We have
After powering up the printer, press Menu, * key, # key (do not hold them, just press and release). You should see a secret menu, the first option being "Serial number". From there, I scrolled down to Network menu -> NVRAM reset to reset the network card. There also seems to be a Utilities menu which allows a full system reset.
Posted on Aug 23, 2010
Larry Dolenak
SOURCE: 1022n print config is showing IP as 0.0.0.0 set in
I had the same problem with this printer. I tried cold resets and flashing the firmware on the printer and still came up with an IP of 0.0.0.0 and the printer still set to manual. Here's what worked for me.
When flashing the firmware the first time, I only had the usb connection from the computer to the printer. After a few other attempts, I tried flashing with the usb cable connected AND the network cable connected from the printer to the wall port. After this the configuration page gave me DHCP and a brand new IP Address.
Here is a working link to the firmware for Windows.
So just simply have the network cable connected while flashing the firmware on the printer, hope this helps.
Posted on Feb 09, 2012
gaurav kumar
  • 53 Answers
SOURCE: How do I factory default settings
The router's admin page is http://192.168.1.1 or http://192.168.0.1 and the default password should be either "admin" or "password" without quotes. There should be a choice under "Setup" called "Factory Reset". That will erase the settings and reset it like new.
Alternatively, you can follow the procedure as given below on all the brands I've tried (Belkin, D-Link, Linksys)
1. hold the reset button for 30 seconds (don't release)
2. unplug the power (still holding reset) for 10 seconds
3. plug power back in (still holding reset)
4. hold reset for another 30 seconds - the lights will usually begin flashing in some odd pattern
5. release the reset button
6. wait 1 full minute or until the lights stop flashing
7. unplug the power for 10 seconds, just to do a reboot
8. verify the settings (e.g. SSID) are back to the defaults
Get instant online router support for D-Link router/wireless router at http://www.vtechsquad.com/wireless-router-support/ to fix D-Link router/wireless router issues.
Posted on Oct 25, 2012
MTS2000 strange tone? and question about top display.
This radio was programmed to work on a networked radio system. They are called many things, but "no sys" means it does not detect the radio system it was programmed for. Look for a channel that says "dir" or "dirc" or like that. It means direct channel, or radio to radio without the range of the system. The PTT or talk button tone is telling you the radio cannot "connect" to the system.
May 31, 2017 | Motorola HT1000, MTS2000, MTX8000/9000...
Can I replace the sensor for a Radio Shack 63-1090?
I presume by sensor you mean the remote sensor not the main unit which also has sensors? When you buy the 1090 you get one external/remote sensor which is also labeled 1090. If you buy extra sensors they are 1092's. Another new 1092 sensor should work with your 1090 it does on mine. You can have up to 3 remotes just set the channel on them. Getting one is the problem. If your talking of stripping the box down to replace the sensor , well I am sure more than the sensor would have a fault!
Oct 29, 2012 | Radio Shack Wireless Weather Forecaster
I need a wire harness for a Cobra 40X CB or at least a description of how to hard wire.
I'm not sure I understand what you mean by wiring harness. If you are trying to wire it to power, and need the power wire, they are widely available. Its a universal plug for cb radios.
Ebay for around $5 search for CB power wire.
Truck stops usually carry stuff for cbs and they will most likely have one.
If you are talking about wiring the mic..... Just buy a mic for it already wired to the plug.
Dec 05, 2009 | Cobra Radio Communications
I can hear people i just cant talk to them
A few reasons for not being able to talk through the mic is that if parental settings are set. Parental settings can stop you from talking and, if set right, can stop you from hearing other people, which isn't the problem. It could also be that the mic on the headset is broken. If it is, you will have to buy a new one. Try using someone else's headset. If theirs works, then it confirms that it is only your headset. If it doesn't, it might mean that either your Xbox 360 remote isn't working right for voice, or parental settings are restricting you from that action.
May 01, 2009 | Video Game Consoles & Games
One micro talk 1 can ring the other and talk & one does not ring
the other set is not transmitting but its able to receive,
so a transmitter be checked.
Mar 29, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Emerson Clock Radio is not working and has odd numbers in display
You can try to reset the microprocessor by running the Clock/Radio with out the battery in. If this works buy a new battery (CR2430) and see if the Clock/Radio functions return to normal. If this does not reset the microprocessor , you will be out of luck with this Clock/Radio. It has had some damage done to the microprocessor and cannot be repair. Emerson does not provide out of warranty repair service. What this mean to you is that there is no support for this product. This means there are no parts or service information to do the repairs with. If the Clock/Radio could be repaired, the repair cost would probably cost you more than the cost of buying a new Clock/Radio. I am sorry to give the bad new. In this day and age of short production run items, it is cheaper for the manufacturer to sell you a new product then repair the older one. I hope this information has help you with the problem you are having with your Clock/Radio.
Jan 19, 2009 | Emerson Smartset Clock Radio
Droped channel to 17 and frequency counter don't work?
sounds like a connection is coming loose inside. take it to a CB shop and see if they can spot it. Should be an easy fix, no more than 20 or 30 dollars
Jan 10, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Cant hear are talk with my lg
Same Here! I can text and the phone will ring but I can't hear, nor can the other person hear me.
May 20, 2008 | LG enV VX9900 Cellular Phone
Radio Communications Logo
353 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
