Normally Sharp Error Codes are 4 characters. It should be E7 and then 2 more numbers.
The E7 family of codes could be a duplex issue, a Laser issue or a few other options. You won't be able to clear the error code on your one. I suggest calling on a local dealer to assist.
If you give me the rest of the code I can tell you exactly what is causing it.
How to Perform Soft Reset of Nokia E7 with Secret Security Code:
Soft Reset Nokia E7 is the recommended try for user who get problem with Nokia E7. Doing the soft reset will not delete any important data, it only will restore the setting files with ini extensions to default on. The default ini files is saved in Nokia E7 rom, so it will not deleted event you already doing the hard reset or format Nokia E7. Do the soft reset easily by Press *#7780# with dial pad to Soft Reset Nokia E7. Please enter 12345 for security code
Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Master reset code:1122 Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
The default security code for Nokia is 12345 or 00000 you can use it. If you want to unlock your Nokia E7 you can use the codes ie the unlock codes. Get the unlock codes using the site Onlinegsmunlock.com and unlock it easily.
E7-11 Shading troble(whife correction) IMPRPER CONNECTION OF THE CCD UNIT CABLE DIRT ON THE MIRROR,THE LENS,AND THE REFERANCE WHIT PLATE copy lamp lighting abnormality ccd unit abnormality MCU PWB abnormality (when occurred in the scan position)improper installation of the mirror unit
