1999 Buick LeSabre Logo
Posted on Jul 26, 2009
Programing a keyless remote for a 97 buick lesabre limited
What is the code for programing a keyless remote for a 97 buick lesabre limited
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Aug 11, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
0
Helped
6719
Points
31
Go to "programyourremote.com" and see if they can help you with your paticular vehicle...
Need access code for keyless entry remote
I found this info in your owners manual, if it won't work, I can't help you. Sorry.
1helpful
The four button remote with keyless entry and remote start on my 2001 buick lesabre has stoped working. The keyless and trunk and horn functions all still work fine just the remote start has quit working. ...
it maybe that the relay in the alarm module for the starting function has stopped working. your best bet would be an alarm shop where they can test the connection for function. have seen this issue several times. Does the engine turn over at all? if it does then the time for cranking may need to be adjusted.
1997 buick lesabre limited will not enter remote programming mode...key in ignition door open insert jumper pin 4 to 8 does nothing... turning key on cycle the lock sequence 1 time but does not allow...
jump terminals 4 and8 close all doors turn ignition on door locks should cycle press and hold lock and unlock buttons on transmiter after a 30 sec delay door locks will lock and unlock disconect jumper
1998 buick lesabre all control (radio, a/c) is off
Hard to say - using the data port to program a remote is unusual, and depending on what device or procedure you used, you may have screwed up the datalinks. You should start by using a code reader to see what trouble codes exist.
Keyless Remote quit opening trunk release on 2005 Buick Lesabre
Trunk reless relay ! Which year is right ? at the top is shows 1992 Buick . An it also has 2005 ? Which is it ?
Replaced battery in keyless remote in 1995 buick lesabre - still unable to open door
sounds like the remote is no good, open it up and look at chip, its a common problem with these older remotes the chip pulls apart from the board, replace the remote.
2helpful
Instructions for programming a 2003 Buick La Sabre Keyless Remote
fifty is cheap and should pay it because no else can program the remote because it must be done through the computer.
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
