Sewing Machines Logo
O
Olga Botsford Posted on Jul 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The bottom thread keeps bunching up and stalls the machine with the #E6. How can I fix?
R.A. Ellis
Level 3:
  • Sewing Machines Master 12,731 Answers
  • Posted on Jul 10, 2017
R.A. Ellis
Level 3:
Answers
12731
Questions
Helped
2613443
Points
59176
Suspect the top thread is not seated completely in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Test your machine.
You can also look in the troubleshooting section of the manual for what the E6 code means.
OR, search for:
Make Model E6
2answers
My thread keeps looping on bottom Have changed tension, needle rethreaded and changed bobbin nothing helps what am I doing wrong?
not sure if this will help you...Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimesthread buching can be caused by something as simple as the tension dial being inadvertently turned.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC ? ' eBay
www.ebay.co.uk/gds/WHY-IS-THREAD-BUNCHING-UNDERNEATH-MY.../g.html..
or you could go to this link and see if it helps you out.. thread keeps looping Google Search
Thread keeps bunching on the bottom of thick material
try a different needle
here's a link to a free manual from singer
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
some machine can't handle thick fabric & some can
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
make sure the thread has not come off the thread take up lever
Thread keeps on bunching up on the bottom side of the fabric
try changing the needle
check the top thread tension to make sure it's not to loose
rethread the machine top & bobbin, make sure the bobbin is wound
correctly & inserted correctly into the machine
Bobbon thread keeps bunching
then it's very possible that the machine is out of time & needs to be serviced
make sure the needle is in serted correctly--flat side to the back of the machine & all the way up into the needle holder
1helpful
When trying to sew my thread is skipping stitches and then the i get a whole bunch of thread wound up together on the bottom. I have cleaned it out but it still wont work. Keep getting an E6 code.
change the needle
rethread the top thread & make sure the top thread doesn't come off the thread take up lever
make sure the bobbin is not warped
make sure there is no lint in the feed dog area
some needles & thread are not compatable-try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
4helpful
The bottom thread is bunching up not keeping tight tried everything to change tension according to the manual I was hopeing I could fix my own problemit has never been serviced before
Make sure your UPPER thread is correctly threaded in the machine, put the UPPER thread tension dial to 5. you can also try it on 6, 7, etc., the higher the upper tension is set the less top thread will show on the bottom of the cloth.
Thread bunches up underneath cloth when sewing then machines stalls
check bottom tension...but first make sure your threading machine correctly
either bottom first or top tension....top tension should be set to 4-5 bottom should feel when pulling about the same tension
1helpful
Keeps "birdnesting", besides rethreading, how do I fix?
when you have bunching on the bottom, you have a problem with the top thread: no tension. (and visa versa) Make sure the thread runs through the tension discs, these discs are activated when you put the presser foot down, so you want to thread the machine with the foot up, also feel if there no burrs, hooks, or whatever, so your top thread comes smooth off the spool, no jerking.
2answers
Brother Embroidery machine thread keeps breaking
the needle thread tension is wrong
bunching up under the material indicates that it is too loose
9helpful
5answers
Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
