SOURCE: Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
SOURCE: conair ww17 scale measures in kg not lb.
There is a switch on the bottom of the scale on mine to use either lb. or kg.
SOURCE: how can change the lb to kg scale
Read the manual, with no luck. Researching further, the website answer is: 'The process for changing the mode of readings is unique to your model. Please check your instruction manual or contact our support representatives at 877-216-1333.'
