I think this is metal scale. If you dont have your manual, consider asking your dealer for advice. If there is no dealer in your area, consider a mild acid wash.
You need to rid the pool from algee. When you say saltwater filtration do you mean a chlorene generator? It generates chlorene from the sodium chloride that you maintain in pool. This still means you need chlorene to kill the algee. Shock the pool with chlorene shock. After allowing the pump filter to mix, let stand ovenight. Vacuum green slime from bottom to waste. Your pool supplier can help you . Kill the algee then start up chlorene generator.
Try making sure filter is installed correctly. Push filter down onto foot ring. Install cartridge support on top of filter with gasket into filter and fingers up. If filter is not seated on top and bottom, debris in water will flow around the filter instead of being trapped in it.
It could be that there is algae growing inside the tank of the filter. You may want to vacuum to waste to get the algae out of the pool and clean out the filter. If you have a Cartridge or DE filter, you will need to do an acid bath for the grids. Take the internal parts out of the filter and clean with bleach water, use bleach water on the tank also.
If you have a sand filter, you will need to empty out the sand, clean internal parts and tank with bleach water then fill with new sand.
The only problem is that ther is a leak in the liner. Generally at the bottom where a rock or debris has made a small hole. They can be patched but the pool will need to be drained. Call your local pool service company.
Kurt
