Question about Kohler Electrical Supplies
How to reset my exercise day and time on a Kohler 20 k
Posted by Dan Regan on
How can I reset the "programmed exercise mode" on my Kohler 12 RES generator
You will likely need to reference your instruction manual for that specific control panel.
Aug 07, 2016 | Kohler 12 kW Emergency Power System -...
Kohler exercise causes engine spikes and gasping for fuel.
On exercise it isn't under load, you may have too much gas pressure, have the gas pressure and fuel/air ratio checked on the mixer
Dec 16, 2012 | Kohler Generator 20kw 20res W/ 200 Amp...
Kohler automatic transfer switch RDT CFNA 0100B. I can set it to exercise and it will do so for several weeks then it forgets. No fault shown.
Product manual does not have troubleshoot section.
The operation might be normal, and within expected parameters, or it might have a glitch.
Suggest you contact Kohler Power directly:
http://kohlerpower.com/contactus/contactus.htm?sectionNumber=
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 29, 2012 | Kohler 100-Amp Automatic Transfer Switch ...
How do I reset the exercise mode to a new date and time on the Asco 165
Press and hold the exercise button at the day and time you want it to exercise. It will remember this time and will then auto exercise. The ex led blinks and for example 7 times, that means 7 days until ex, then 6 and so on. I hope this helps, emerson power have manuals, or I can send one let me know
Dec 05, 2011 | RTO ASCO 165 Series 200A Automatic...
How i can loose tummy
Hello Dear
If you really want to loose your tummy, do the following easy exersise (if You are not asthamic) any one
1. Climb Stairs 10 to 15 times a day. Start with 5 times then increase it by 2 times daily that is
1st Day= 5 times
2nd day= 7 times
3rd Day= 9 times ..... and so on. till day 10. Increase it to 20 times a day and then stop increasing vut continueing your exercise. In 35 days You will feel the difference in your tummy.
2. Cycling: Lay down straight on your back with your hands under your head. And in air use your legs like you are cycling in air... Start this with 5 mins daily and proceed it to 20 mins daily.
It will take you a month and you will feel your tummy loose as faster as any other procedure or machine using exercise.
Note: Exercise 2 is proved by 10 other peoples. It is Granteed.
If you like my Solution please rate it.
best wishes
Mar 03, 2011 | Healthometer Health o meter Body Fat...
If I lose street power momentarily and my generator immediately starts than quits because the street power comes back on, the weekly 20 minute generator excercise does not work.I have to reset the transfer...
Although A bit inconvienent this does seem to be the norm for some Kohler units. Actually a small price to pay rather than having a technician come out to replace the ATS control board. There are time delays that could be set longer to keep the unit running longer and may prevent this from happenng
Jan 03, 2011 | Kohler 18RESL 18 kW Emergency Power...
What is the proper proceidure to set exercise timer on a briggs generator model # 01938 and what year was this model manufactured? thank you
http://www.homegeneratorsystems.com/service_support/manuals/index.cfm?rd=1
This link will take you to their site where you can download their manual.
Setting Exercise Timer
The Home Standby Generator is equipped with an exercise
timer that will start and exercise the system once every
seven days. During this exercise period, the unit runs for
approximately 20 minutes and then shuts down. Electrical
load transfer DOES NOT occur during the exercise cycle
(unless an utility power outage occurs).
A switch on the control panel is labeled “Set Exercise”
(depicted on page 10).The specific day and the specific time
of day this switch is pressed is programmed into the
control board memory.This date and time is then used to
automatically initiate the system exercise cycle.
To perform the Set Exercise procedure:
1. Choose the day and time you want your Home
Standby Generator to exercise.
2. On that day and time, set the AUTO/OFF/MANUAL
switch to OFF.
3. Press and hold down the “Set Exercise” switch for two
seconds.
4. Set the AUTO/OFF/MANUAL switch to AUTO.“Set
Exercise” is complete.
For example, if you press the “Set Exercise” switch on
Sunday morning at 10:00 AM, the unit will run an exercise
cycle the following Sunday at 10:00 AM (+/- 1/2 hour).
NOTE: “Set Exercise” will only work if the unit is in the
Automatic mode and this exact procedure is followed.The
exerciser does not need to be re-set if the 15 Amp fuse is
removed or changed.The exerciser will need to be re-set if
the 12 Volt DC battery is disconnected.
If you want to change the day and time the unit exercises,
simply perform the “Set Exercise” procedure at the exact
weekday and time you want it to take place.
• To prevent possible injury that might be caused by such sudden
starts, always set the AUTO/OFF/MANUAL switch to OFF.
• Remove the 15 Amp fuse before working on or around the
generator or transfer switch.
Nov 12, 2009 | Briggs & Stratton 12,000 Watt Bi Fuel...
My Kohler 17RES has stopped doing it's scheduled weekly exercise. How can I get it exercising again?
On your Automatic Transfer Switch ( the little gray box you see on the right in the picture above) you have two blue buttons. One is a Manual test switch. The other has a clock on it and this is your exercise set button. Hold it down for a FULL 3 seconds if you want it to excercise without a load (not powering your home) Hold it down for a FULL 6 seconds if you want it to exercise with a load every week. Your generator will start and run for 20 minutes, and then shut down. Now every week your generator will exercise at the time and day that you pushed the set button.
Aug 08, 2009 | Kohler 12 kW Emergency Power System -...
Electrical Supplies Logo
1,549 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Tim Venetis
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
