By stripped, do you mean the head is stripped, or are the threads stripped.
Head stripped = Damaged Screw Extractor Drill Bits 4 in 1 Bolt Extractor Set Easy Out...
Stripped threads = You need to "drill off" the head of the stripped screw. Get a sharp drill bit that is at least twice the size of the threads. Drill into the screw head until the entire head is gone or can be removed..Once the entire head is gone, you should be able to remove the cover..once the cover is off, you should be able to remove the screw with vise grips or other suitable tools.
SOURCE: Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
SOURCE: briggs a stratton 35 lawn mower
Turn the mixture screw on the carburator slowly counter clock wise till the idel stabalizes.
SOURCE: lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
