Question about Palm Computers & Internet
My palm has a hole in the bottom - Palm Computers & Internet
Posted by letitia reuther on
Whats are the name of beetle insects that destroying oil palm?
The red palm weevil, Rhynchophorus ferrugineus, is a species of snout Beetle also known as the Asian palm weevil or sago palm weevil. The adult beetles are relatively large, ranging between two and five centimeters long, and are usually a rusty red colour - but many colour variants exist and have often been misidentified as different species (e.g., Rhynchophorus vulneratus; ). Weevil larvae can excavate holes in the trunk of a palm tree up to a metre long, thereby weakening and eventually killing the host plant. As a result, the weevil is considered a major pest in palm plantations, including the coconut palm, date palm and oil palm
4helpful
How do i perform a hard reset on my palm pda
  1. Step 1 Straighten a paper clip into a single line.
  2. Step 2 Locate the "Reset" button by spotting a small hole on the backside of the Palm Zire 31.
  3. Step 3 Push the power button on the Palm Zire 31 with your finger and hold it down steadily.
  4. Step 4 Push the paper clip into the "Reset" button's hole while holding down the power button.
  5. Step 5 Release the power button once the screen displays the "Palm Powered" logo.
  6. Step 6 Push the navigational key in the "Up" direction to complete the Palm Zire 31 hard reset.
1helpful
My PalmOne Tungsten E2 is stuck on cancelling Blazer
Usually I just hit the reset button and hope nothing was corrupted. Just use your stylus or a pin and press the reset button in the hole on the back/bottom of the palm. It will then reboot and you should have control back. Blazer is pretty stable but once in a while it acts up.
1helpful
Z22 palm handheld touchscreen won't respond - i've done soft reset -- several times -- used the 5 way to bring up the touchscreen -- tapped and nothing happened.
Hi, Try doing a hard reset to see if this will correct the problem.
Hold down the power button and at the same time use the tip of your stylus or any other non sharp item and press the inside the reset hole on the back of your palm.
When you see the Palm power logo appear you can let go of the power button and also the one on the back of you unit.
It will display a message asking if you want to do a hard reset and that it will erase all your data. select yes by hitting the up part of your 5 way button on the bottom of your unit. This is the one you use to navigate around your palm screen. After it resets you wil then be prompted to reset the screen by tapping the targets. If it works great. If not then you have something wrong that needs to be looked at. Before you send it in go to:
www.palm.com.
Select pda and then your model. From there go to the support screen and do a live chat. This is free and they may be able to live you some help. Best wishes.
Palm Z22 will not turn on and I don't know where to reset.
the reset button should be located on the back to the bottom right of the label.
have a look at this link.
http://www.palm.com/us/images/support/kb/articles/30113_z22.gif
1helpful
Hot Synch an existing PalmVx data to a replacement palmVx
HI,
The first thing you want to do is to do a Hard Reset on the used PDA that you bought as a replacement. To do that follow these steps:
1. Hold down the power button and then depress the small hole in the back with the tip of your stylus.
2. Continue to hold them both in until you see the Palm logo.
3. Let go of both of them and then follow the onscreen directions. You will want to answer yes and use the 5 way navigation button on the bottom of your pda and hit up so that is completes the reset. After that you will have to set up your touch screen and go through the tapping the target. After you have gone through all this then do a hotsync2.gif. It should clear up your problem. Best wishes.
Palm i705 won't turn on
are you certain that the belkin universal charger, is compatable with the palm ?
if any single cable, is wired differently. this could have damaged the palm.
try a hard-reset using your palms user manual.
this varies between pdas, usually comprising of either a reset hole, at the bottom of the palm, or underneath the battery on certain models.
i,d suggest obtaining the correct charger/usb cable.
as you may cause damage to the unit. most new devices have a battery fitted, but does not necessarily mean it,s charged.
Hope this helps, please rate the solution.
Mike @ compurepair.
1helpful
How do I make a hard reset on my Palm Zire 31 PDA?
There is a reset pin hole on the back of the unit; Hold the power button and push the reset button in the hole with a paperclip. All memory should now be erased.
4helpful
2answers
Palm T3 frozen, tried restart in hole, nothing?
take the battery off for 15 seconds and put it back again. you need to reboot your Palm at least once a week. goodluck!!!
Won't shut down
There are a couple of things you can try.
1- Poke the hole in the back where it says reset.
This will in essence reboot your Palm.
2- Make sure the Auto-Off after: is set to 2 minutes by going into the Preferences, Power section.
3- If your Palm is not holding charge, connect the Palm to charge it. Turn the Palm on and make sure the battery at the top has a lightning bolt going through it. This will let you know it is charging. Then, push the reset hole in the back to reset the Palm. This should reset the charging mechanism in the Palm and allow your battery to hold power.
If the Palm does not hold power after step 3, you may need to see about getting it serviced.
Computers & Internet Logo
Top Palm Computers & Internet Experts
Ekse
Mandeep  Singh
Mandeep Singh
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
