Question about Sanyo Cameras
In my Sanyo VPC e2100 found a AA battery had leaked into the chamber. Cleaned the area with a Qtip and white vinegar. The chamber looks dark and discolored & still not working. Can I get this fixed?
Posted by Danielle Gemme on
Tony Parsons
  • Sanyo Master
  • 6,302 Answers
Maybe, but it will be expensive. May be cheaper to replace the item.
Posted on Jul 07, 2017
Sanyo VPC-S1415 lens stuck in camera
that's happen due to physical damage like dropping etc.
try to open inside and align well the lens mechanism
Jul 01, 2016 | Sanyo vpc-s1415 - Vpc-s1415 14.0...
Sanyo vpc e2100
DRIVER problem. Update you system through Windows Update ( if it originally !! ) , or look for driver of your vpc e2100 on Sony druvers site. ATTNTION : you need for searching that driver , your exactly type of your serial of your DEVICE. Best reggards
Aug 14, 2013 | Cameras
Sanyo
The VPC-S770R uses standard AA batteries. Chargers for rechargeable AA batteries should be available at just about any department, electronics, or office-supply store. Do NOT try to recharge non-disposable alkaline or lithium batteries. Also bear in mind that the camera itself is not a battery charger. If you want to use rechargeable batteries then they must be charged outside the camera using a separate battery charger.
May 11, 2013 | Sanyo VPC-S770R 7.1 Megapixels Digital...
How can i increase the dof on my camera--- and how can i set tne aperture on my camera--sanyo-vpc-e2100
Take a look at this.
You can set the aperture directly in the Manual and Aperture-priority modes and indirectly in the Shutter-priority and Program modes. See pages 39-40 of this manual.
Nov 06, 2012 | Sanyo Vpc-e2100bk 14mp 21x 14mp, Camera,...
Battery problems
well you have to change the batterys you can either search in walgreensor a store near you if they have the same batterys then all you have to do is replace them and your done if this doesnt help then im really sorry
Apr 08, 2012 | Sanyo VPC Cameras
How to set the shutter speed on the sanyo vpc-e2100
Actually, you can set this cameras shutter time by 1) Set top knob to M 2) Make sure that the bottom of the screen displays this "OK: Adjust" in yellow letters, and below this it tells you the the F: variables, and the Shutter speed. From what I have experienced, this only goes up to 15 seconds. But, this is great for light painting in total darkness!!!
Jan 27, 2012 | Cameras
I have a sanyo vpc-e2100 and there is a delay in taking pictures. how can i chang it
press the flower button next to the ok button look at screen when u see pf in the lower left corner it is on this will stop the delay's
Jan 07, 2012 | Sanyo Cameras
What type of battery is recommended to use in a SANYO VPC-S770?
With your Sanyo camera, you've got the choice to use AA alkalines or NiMHd rechargeable batteries.
Two suggestions: if you are still not comfortable with recharge batts, you can simply take along an ample supply of AA. Currently there are newer AA batts that are designed for extra life as well.
But if you want to give rechargeables another try, look for batts that have a higher mAh rating.This is the batt's lasting power..
So if you can find a 1600, 1900, .... the higher the better.
Jun 16, 2009 | Sanyo Xacti VPC-S770 Digital Camera
Cameras Logo
52 people viewed this question
Top Sanyo Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
