Question about Refrigerators
Jenn-Air JFC2089HES (French Door) Fridge not cooling enough
The freezer is cold but the fridge is warm.
I took the panel off from inside the freezer, a bit of frost even on the grid.  Unplugged and cleaned up the frost.  Retested - same problem.
Reopened up the panel after 6 hours and same amount of frost on the grid, rechecked all plugs in there and they look fine.
Fans are working, and vent valve in fridge is opening up to allow flow, cool air is entering the fridge (seems enough to cool it down but it's not working).  Lights are going off.
Unit is two years old.
Hmmmmm.  Anyone have any tips?
Posted by northrock on
  • 1 more comment
  • Anonymous Dec 10, 2007
    I have the same problem...did this every get fixed?
  • Anonymous Jun 10, 2008
    Our fridg. has never worked since we bought it in 2005.  Same type of problems from the freezer being too cold to the fridg. and freezer barely working at all and food being ruined.  We've done the same as you have but it still gets like this every few months.  We would love to chuck it, but only 3 yrs. old.  Our 30 yr. old fridg. we got rid of worked so much better.
    Kathy and John
  • weggenmann Dec 02, 2008
    We have the same problem. We cleaned out dust around the bottom of the refrigerator and that seemed to work for about 2 weeks then it got warm again. The door frames around the refrigerator are really warm to the touch also. Somebody help!!
Anonymous
Hey Northrock,
Did you ever get your fridge fixed? I have the exact same fridge and the exact same problem.
Posted on Dec 10, 2007
Jenn-air gasket is hot
The refrigerator portion is fed cold air from freezer section to cool it. Check for the freezer fan and/or the damper mechanism that directs air into fridge compartment for proper operation.
Sep 03, 2017 | Jenn-Air Refrigerators
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
Freezer is cold but refrigerator is warm. What do I check?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 31, 2010 | Jenn-Air JFC2070KRS Stainless Steel Bottom...
Refridgerator is warm freezer is cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 29, 2010 | Jenn-Air JFC2089HE French Door...
Refrigerator is warm and freezer is cold
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 21, 2010 | Jenn-Air JFC2070KRS Stainless Steel Bottom...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator. One month ago the water tap stopped working then I noticied that the top doors to refrigerator would not reliably close like they used to. Last...
The water could have been frozen in the door and melted when your fridge warmed up.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Jun 11, 2009 | Jenn-Air JFC2089HE French Door...
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Refrigerators Logo
778 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
