SOURCE: I need serial # for a Philips Gogear SA177/00
sf000532001532 it's mine but i cannot charge it anymore. so i think you can use it!
SOURCE: sa177/00 "recovery mode" problems in Philips Firmware Manager
Try to defrag the drive .... is not workd thn format it manually frm PC n reset the set hopefully it will get back to normal. i did this with mine go gear n its fine now.
SOURCE: How do you delete videos and photos from a Philips
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
SOURCE: Philips 8gb Gogear SA3085/02 -"DRM License not available"appears
In your Windows media Player go into tools and select options. Select rip music and untick copy protect music. The music you have in WMP wont work. you will have to put them in again after you made the changes. Hope this helps
SOURCE: It says on the phillips
yes your correct there are different types /size of mp4 s here is a video on Philips site that explains what sizes format are acceptable usually the player comes with a disc that has a free tool to convert videos to proper sizes hope this helps and please vote
