Question about American Standard Home
I have an American Standard jetted tub that was installed in 2003 and I need to remove the jets. How do I do this?
Posted by JoAnna Sanders on
4 Related Answers
Alan
  • 80 Answers
SOURCE: how do you remove the jets on an american standard whirlpool tub
The jets have a nut on the back of the jet. I hope you have access or else you will need to pull the tub for this job. Loosen the nut and squeeze aquarium grade silicone in between the tub wall and the nut, Tighten the nut, but not to tight. Let set over night fill and check for leaks the next day.
Posted on Sep 19, 2009
Alan
  • 80 Answers
SOURCE: i have an american standard jet tub, but i lost
You can adjust the jets by moving the center of the jet around, if the center does not move, it is not adjustable, some jets have a pressure adjustment by twisting the center of the jet left to right. No manual necessary for this.
Posted on Mar 26, 2010
uspartscente
US Parts Center
  • 719 Answers
SOURCE: My American Standard spa tub Williamsburg Elite
sounds like maybe the jet faces are turned off. see if they turn one way or the other and they may open and spew water out for you.
Posted on Jan 12, 2011
P Marsh
SOURCE: when I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Posted on Aug 19, 2012
Hydromassage 1063
Not normal for that to happen but the jet faces on the two back jets may be turned off or down.
Try turning the face of the jet clockwise and see if you get more water flow out of each jet.
Rod
US Parts Center
Apr 13, 2014 | American Standard Home
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
My American Standard spa tub Williamsburg Elite Model 2425E has a couple of the eight jets failing to jet, the two on either side of the rear left corner.
Dec 31, 2010 | American Standard Home
How to remove jet rings on jetted tub
It depends on the brand of jet and tub, if it is a gold or silver trim ring, they will generally pry off with a screwdriver, just be careful not to damage the tub when doing so. When prying, move the screwdriver around the jet an inch at a time, just like opening a can of paint. Some rings will screw on, but most just pry off.
Mar 24, 2010 | American Standard Home
I have an american standard jet tub, but i lost
Mar 13, 2010 | Home
How to remove jets from american standard jetted tubs for routine maintenance
Jet trim usually unthread counter clockwise out of the wall fitting
Sep 21, 2009 | American Standard Home
How do you remove the jets on an american standard whirlpool tub they are leakin and i believe the seals are bad
Sep 15, 2009 | Home
Home Logo
87 people viewed this question
Top American Standard Home Experts
Mike
john h
Bill Johnson
Are you an American Standard Home Expert? Answer questions, earn points and help others
