SOURCE: setting up wireless network 4 computers with Netgear
Assuming they all will work with the version of wireless the netgear works with (802.11a/b/g) then you really just need to enable the wireless network on the netgear and choose how you want to protect it. I recommend using WPA or WPA2 if all your devices will support it - this depends on the wireless cards in all your pc's - just set up a name for the wireless network (not recommended that you use the default because everyone does) set up your WPA/WPA2 passphrase on the netgear and it should be pretty much ready to go. On each pc then, once they are able to see the wireless network with the unique name you gave it, just hit connect in your wireless settings and enter the passphrase. Each pc should be set up.
The only other thing to consider is to make sure they are all using DHCP via the wireless router or, if you prefer setting up their IP addresses manuall, make sure none of them conflict with eachother (each one needs to be unique).
SOURCE: Beeping with no boot up
Beep codes mean something has gone wrong with the computer. Beep codes most likely happen for: Memory, Processor, Motherboard.
Try reseating the memory in the computer.
SOURCE: i need help
you should be able to go to toshiba support and locate yur model and download the latest chipset drivers
SOURCE: hi there, seem to have lost my external harddrive
Hard drives don't beep. They make a lot of sounds, but no beeps. If the drive is actually making an unusual noise, it has probably gone bad. Clicking would be a bad disk. Any other noise would be a bad controller board. A good shop may be able to slave your drive to another computer to try and save your data. But don't count on it. By the time a drive makes a loud noise, it's usually gone and unrecoverable.
Before spending a lot of money to recover your data, try the external drive on another computer. Maybe the connection USB port has gone bad on the original computer.
