Sounds like the motor is trying to run but the other machine parts are not moving. If your machine is an older mechanical (not computerized), then it's very possible the machine has seized due to lack of regular cleaning and oiling. Avoid trying to run the machine in this condition as it can damage the motor.
Most foot controllers are attached to the cabinet to be used as a knee control. If yours appears to be a foot pedal and the cords are long enough, you can probably remove it from the cabinet and try it on the floor.
The pedal is stuck in the ON position. Unplug the sewing machine and try to open up the pedal to inspect it. Or try pressing the pedal a few time to loosen up the pedal movement. Good luck!.
Diane, Check the attached links, not all are free.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Most machines have a button that is on the front of the machine. It is located on the front with machine with the stitch selections. The button is pushed in. Push the center button again and if that doesn't work, push the outer edge of the button and it will release.
A model # would help. Do you have a manual? You can look for the riccar website and search the manual. If its available as download, you can use the CTRL+F function to "find" words like lock, needle, or other things that can narrow it down.
Here are some other riccar sewing machine fixya posts that you might look through. http://www.fixya.com/tags/needle_not_move_down/browse/riccar
Today I got such a machine (Riccar) for free from a lady I know. the only problem was that the needle walked against the bobbin (timing problem).
I screwed the sewingmachine open and after some screwing I saw that the part, Hook Drive Gear, Riccar #53741, was broken. Wat I did is I enscrewed two screws wich hold the part on the axe and with a bigger flat screwdriver I could just push the part from the axe, from the other gear. It looks more difficault then it is.
Now I have to get a new part, put it back and time the the machine so that the needle will go normal, at the right time, in the bobbin. Does anybody know the trick to do that?
