Refrigerators Logo
How do you reset the control panel for a Bosch refrigerator?
1helpful
How do I reset/unlock the control panel on my Bosch fridge freezer?
Try some of these answers. I'd also suggest unplugging it, waiting a few minutes and plugging it back in. Can't hurt!
Samsung refrigerator alarm beeping continuously
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Panel beeping and nonresponsive
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
How to reset a filter display on a bosch refrigerator
from our bosch manual: press and hold the light/filter button for 3 seconds. the water symbol is reset. the symbol stops flashing. the new filter cartridge is activated.
Control panel light does not come on, light in freezer and refrigerator does not come on. Tried to run self test unable to get buttons on control panel to turn on. Tried alarm button. Also, no ice,...
Does ANYTHING work? Sure it's plugged in, breaker not tripped and GFI plug not tripped?
Plug something else into the outlet to confirm that it works.
Unplug from wall for 30 minutes to reset Bosch to defaults.
Still malfunctioning? Main control board is faulty.
Fridge / control panel has no power; freezer light working
If there is power going to panel but the panel isn't working, then it should be replaced. If there is no power going to the control board, then trace the wiring and test all components with a voltmeter.
1helpful
How do I reset an old Bosch dishwasher SHI4302UC ?
Assuming that you can control power to the dishwasher from your kitchen panel switches, hold down the power on switch on the front panel of the dishwasher and recycle power (switch off and on) at the kitchen panel switch.
This will reset the dishwasher.
3helpful
Asterisk symbol Bosch Refrigerator B20CS50SNS
It means it is time to change the water filter. You can hold the button down for a while and it will reset whether you change the filter or not.
Top Bosch Refrigerators Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
