Question about Razor Dirt Rocket MX 650 Electric-Powered Replica Dirt Bike
My MX 650 razor dirt bike is broken the back suspension is broken and it won't turn on what do I do
Posted by bill thompson on
steve
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Razor Master
  • 35,303 Answers
Fix it???
Posted on Jul 03, 2017
Our Razor MX500 won't run with out giving the motor a little help getting going. We took the motor off and hooked it to a battery charger and it works fine, you put it back on the bike and it won&
remember the motor transfer the power to the front..there no weight on the motor when you take it off..the motor can be going bad/a singnal! most people change the battery without checking the motor for wear..
Sep 14, 2012 | Razor MX500 Dirt Rocket
My razor mx 500 motor won't turn.
I think you are talking about an electric motor on your bike . If the motor is New you may have a bad throttle switch . You can use an ohm meter to check the throttle switch . Connect the two leads of the ohm meter to the wires of the throttle switch ( dissconected) . As you turn the throttle the ohm reading should coraspond to how much you turn it .
Jan 15, 2018 | Razor MX500 Dirt Rocket
My back tire isn't spinning
WOW!!!WHAT A JOKE!MY KID SAVED $470 AND PURCHASED HIS MX 650 ONLY TO HAVE THE REAR FREEWHEEL BREAK THE FIRST WEEK RIDING IT.NND BY SEEING ALOT OF THE SAME PROBLEMWITH EVERYONE ELSE.RAZOR SHOULD' VE AT LEAST PUT A HEAVYDUTY ONE IN IT.OK PEOPLE LETS FIGURE IT OUT IF ANY ONE KNOWS AGOOD BEARING COMPANY,POST IT.MY KIDS BUMMED HE CANT RIDE IT
Dec 26, 2010 | Razor MX650 Electric DirtBike
Mx500 Razor Dirtbike battery issue
you could try charging it if this dont work you will have to replace it
Apr 02, 2010 | Razor MX500 Dirt Rocket
Razor MX 650 wont run
i had the same problem but fixed it this morning, i just sat far back on the seat when turning throtle with all my weight and then slid back on normal when moving, but it makes a grinding noise.
Jul 23, 2009 | Electric Razor Pocket Rocket Ride-on...
Razor Dirt Rocket MX 650 Electric-Powered Replica Dirt Bike Logo
460 people viewed this question
Top Razor Cycling Experts
Andrew Taylor
Andrew Taylor
ray gallant
steve
Are you a Razor Cycling Expert? Answer questions, earn points and help others
