Question about Cambridge Audio Audio Players & Recorders
Cambridge Audio Azur 640A Amplifier "replace fuse"
Posted by Nicola Pascale on
5 Related Answers
fixyathing
jhun T
  • 341 Answers
SOURCE: The left channel in my cambridge azur 640
have the volume control cleaned by a spray of electronic contact cleaner. If the carbon coating material is already wiped-out due to use, have the part replaced
Posted on Aug 03, 2009
Grubhead
Grubhead
  • 5750 Answers
SOURCE: Cambridge Audio Azur 340A amplifier,no sound
Start with the basics first. 1. With the amp on, in each imput socket plug a dual end phono cable in and touch the right and left plugs with your finger. You should get a buzz on each speaker. No buzz and the channel at that terminal is not working. If none of the terminals buzz. Then the amp is dead.
If some buzz and others not you have a pre-amp problem.
2: Amp Dead. Could be A power supply. B main pre-amp. C Power Amp.
The power supply check for a fuse.
The main pre-amp will only effect both channels if an IC controls both.
The Power Amp will again only loose both channels generally if it is an IC. It will be attached to a big heat sink and have lots of pins comming from it.
If it uses transistors for the main amp, you can check these with an Ohm meter. With the power off place the leads on each terminal of each transistor. If the meter goes fully over (like when you touch the leads together) each way it has shorted.
The thing to remember when repairing stereo amps. Is that the amp is two identical amps joined together. So what happens one side will happen on the other. If both channels don't work look for something that is common to both.
Good luck
PS never heard of 'cliperd'.
Posted on Sep 25, 2009
Grubhead
Grubhead
  • 5750 Answers
SOURCE: I have cambridge audio azur 640a amp. Problem I
The fault is on the amp! It sounds like the protection circuit is detecting a surge on the channel and shuts it down to protect the speaker. I would check the semiconductor device(s) for the right channel on the heatsink of the amp. You might even see damage of burning on one!
Posted on Jan 04, 2010
Anonymous
  • 73 Answers
SOURCE: I have a Cambridge Azur
Yes, you are right. That's a protection feature to prevent burnouts. Typically it appears when your speakers are sucking up a lot of load from the amp. Please check your speaker impedance and the amps' output impedance and ensure the wiring are properly done. Some amps are soo sensitive that they may cut-off after certain level due to overload.
Posted on Mar 06, 2011
Anonymous
  • 73 Answers
SOURCE: cambridge azur amp 640a working
Looks like the fuse blown.. or the classic symptom of electrical fault inside the amp. 640A uses a sensitive protection circuit often ends up in this irritating situation. Normally, there is nothing much you can do, but just check your wall plug connection for Open Ground or Left & Neutral reversed issues. If the wall plug is free of error, then you should better contact CA technical support.
1helpful
Cambridge Audio Azur 640A V2.0 not reacting to remote control
If your Cambridge Audio Azur 640A V2.0 amplifier is not responding to the volume buttons on the remote control, there could be a few possible causes. Here are a few things you can try:
  1. Check the batteries: Make sure that the batteries in the remote control are fresh and inserted correctly.
  2. Check the remote sensor: Make sure that the remote sensor on the amplifier is not blocked or covered by anything. Also, ensure that the remote sensor is pointing towards the remote control.
  3. Check the remote control functions: Make sure that the remote control is in the correct mode, and that you are pressing the correct buttons for the volume control.
  4. Check the connection: Make sure all the connections between the amplifier and other components are secure and tight.
  5. Check the potentiometer: The potentiometer (also known as the volume control) is the component responsible for controlling the volume of the amplifier. If the potentiometer is not functioning properly, then the amplifier will not respond to the volume buttons on the remote control.
  6. Contact Cambridge Audio: If you have tried all of the above steps and are still unable to get the remote control to work, contact Cambridge Audio technical support for further assistance. They will be able to provide you with additional troubleshooting steps or advice, or they may need to send a technician to repair or replace the amplifier
Cambridge audio 640a problem, olume goes to zero, I hear a little bang on speakers, light starts blinking!
This sounds like there's an overload in the main amp section. Often caused by a short-circuited device.
I cannot open my cambridge audio 640A compact disc
This is a common issue with all belt-drive cd players, all you have to do is to change that belt and you should be done, or take it to a shop for servicing, as this is a part of a simple service maintenance routine, cheap fix though.
1helpful
Running four S70 Siroccos off the amp, everytime volume gets halfway the protection is cutting in with protection light flashing three times? When reducing down to two speakers amp cuts out three quarters...
You are overloading your amp. IMO 640A cannot handle heavy loads.
Better change the speaker combo and connect something that puts right load on the 640A. Else, get a meaty amp from CA.
1helpful
HI, Can the Cambridge Audio 640a integrated amp be used as a preamp if I buy a separate power amp.
Of course, just run an audio RCA pair out from the Pre Out to your next amp and any input. All control for volume, tone, etc will remain with the 640A.
Cambridge azur amp 640a working brill till yesterday !! now protection light !!!! turned it off numerous time etc plenty of venterlation carnt get it to work
2answers
The left channel in my Cambridge Azur 640 amplifier keeps cutting out. Wierdly I can often 'shock' it back to life by quickly turning up the volume a lot. Any ideas?
1helpful
230 Voltage
Good Day sir, yes the 640a has a voltage selector switch.
http://www.cambridgeaudio.com/support_products.php?PID=105&Title=Support
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
