Question about Mercury Boating
OD243947 spark plug for this particular outboard 60hp 2 stroke 3cylinder fuel injected motor?
Just want to know the spark plug no to this mercury outboard 60hp 3 cylinder fuel injected plz
Posted by Satya on
Steve P
  • Mercury Master
  • 3,712 Answers
BU8H - NGK
Posted on Jul 03, 2017
I have a 2014 60HP Mercury outboard 4 stroke motor, where is the voltage regulator and how do i replace it?
It's on the Port side of the engine. Just above the oil filter. There are some electric connetors bolted at the same time.
It's held on the engine by 2 metric 6 bolts, use a 10mm wrench.
Partnumber 893640T01
Sep 22, 2017 | Mercury Boating
WHATS THE FUEL AND OIL RATIO FOR 25HR 2CYL OUTBOARD MERCURY
need the year of manufacture as some 2 stroke units have oil injection that automatically mixes the oil in the correct ratio for engine rpms otherwise it is 50:1 ( 50 parts fuel to 1 part oil)
oil requirements --certified tc-w3 2 stroke outboard oil ---not ordinary engine oil
reference
google --type in mercury outboard oil to fuel ratio
May 07, 2017 | Mercury Boating
What year is a mercury 35hp outboard motor with serial number2491265.Is the motor 2 or 4 stroke
the serial number begins 2487558 and continues past 2491265 and as the beginning serial number denotes the year , your engine is 1969 model
it shows as a 2 stroke with auto oil injection
check the heads
if the plugs are in the flat of the head and there are no rocker covers it is 2 stroke
talk with a mercury /mariner service center
Sep 25, 2016 | Mercury Mariner Starter, Outboard, 35-40...
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
http://www.cottagetips.com/tips/boat-motor-gas-to-oil-ratios
Apr 15, 2016 | Boating
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
L was driving my boat and the out board motor stopped l tried to start it but it smelt like it was flooded .l pulled the spark pulgs out cleaned them and tried to start the motro without the spark plugs to...
If i had year make and model I could give you detailed instruction. You can do a few simple test to make the troubleshooting easier. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard owner you will always need them. Troubleshooting (1) check compression. without the year make and model I'm giving you a average numbers. Look at your Clymer manual for exact numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten.Ethanol gas is proven to stay stable in fuel systems for only 30 days in 90 + degree heat. It turns to a gummy residue called varnish. It clogs up carberators and fuel injection system. I don't know year make and model so i dont know what fuel system you have. clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine cover clean it. mercury fuel injected outboards has a canister fuel filter under engine cover. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing on fuel delivery system. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
Nov 04, 2009 | Boating
Skipping, lack of power, 4 stroke mercruiser
has your boat been sitting more than 60 days. ethanol gas has been proven to only stay stable for 30 days in 90 degree + weather. Labor cost can be up to $100.00 per hour. CHEAP TEST- compression, spark, and fuel. TOOLS(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard owner you will always need them. TROUBLESHOOTING (1) check compression. without the year model I'm giving you a average numbers. Look at your Clymer manual for specific numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing its fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
Sep 08, 2009 | Light Outboard Motor Boat Bass Fishing...
1974 60hp johnson outboard won't run on full throttle under load , max 10%. New fuel and filters ect. The motor is old but has very low hours.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Apr 12, 2009 | Boating
Boating Logo
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
