SOURCE: E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
SOURCE: whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
SOURCE: Kenmore 417. 4405200 Front Load Washer error code E43
It's a bad wax motor inside the door latch. The diagnostics are buggy and do not test it properly. It should measure about 1.5K ohms, and when 120 VAC is applied to it, it should extend in about a minute. Part number 12002535 is $10 to $15.
