SOURCE: I BOUGHT 50 PINT DEHUMIDIFIER AT CANADIAN TIRE
Try cleaning the filter first. Pull it out and then wash it with water and let it dry overnight. Then clean the spigot/nozzle which fills the pan. This often becomes clogged with dust or debris or even insect webs. Once you wipe the nozzle with a rag, really clean it well with a finger. You should feel the rubber gasket at the end of the nozzle with your finger.
Likely the fill nozzle was just clogged so water drips along the top and down the sides of the pan instead of into it.
Good luck.
There are many reasons for a dehumidifier to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
SOURCE: I have a Kenmore 50 pint dehumidifier Model 580.54501400
It looks like it is simple to get the filter out but we are finding it to be imposible. How can we take it out. It doesn't just pull down.
SOURCE: Frigidaire 50 pint dehumidifier freezing up and
Dehumidifiers freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
SOURCE: Garrison 50 pint dehumidifier/ AC unit. Showing
Drain line stopped up .
If no drain line? Unit has to be emptied regularly
answers.canadiantire.ca > ... > Heating & Air Conditioning Q & A
There
are many reasons why a dehumidifier will not work or collect water.
Here
Dehumidifier
heatman101
