Question about Furuno GPS
How do I get to the internal battery in my furuno 1650f gps
Posted by Judy Calvo on
3 Related Answers
Anonymous
  • 34 Answers
SOURCE: furuno gps wiring diagram for usb
Hello!
I have the connection diagram for the GPS unit below.  It should be simple to wire up.  You will need a USB to RS-232 converter, which is available in a number of computer shops/Radio Shack.
Hope this helps you out,
Posted on Jan 07, 2009
Anonymous
  • 111 Answers
SOURCE: may i upgrade furuno 1920 gps/ploter with radar
If it has a round radar plug in the back then the answer is yes and it already has radar support. However to upgrade your unit to the latest software you will need a dealer for that. It's a very tricky process and if not done properly, you can ruin the bootloader programming that starts the unit. I know of a dealer that does this if you want to check in with them. You can even send them the unit. Try www.mid-shore-electronics.com.
Posted on Jan 25, 2010
Anonymous
  • 111 Answers
SOURCE: how many pins on the furuno 1650F?
depending on which port you are referring to: The power has 3, the datas have 6 and 7 and the transducer plug has 10 pins.
Posted on Jan 07, 2011
How do you replace the battery in my gps unit. furuno 1650
The battery is soldered and glued into the unit.The battery is a CR2450-3 volt lithium battery and apparently, easily found at radio shack for 7 bucks.
Oct 19, 2014 | Furuno 1650wf Gps Fish Finder Combo...
Where is the batterie
If you're talking about the memory battery it is internal to the GP1650F. Typically a button style with solder tabs.
May 20, 2014 | Furuno 1650wf Gps Fish Finder Combo...
How to change details on a data card for Furono 1650F
You can't write to a chart card if that's what you're referring too.
Oct 22, 2013 | Furuno Boating
Does my furuno GP32 have an internal antenna or do I need the to install the extra one?
Hi!
Your Furuno Does NOT have an internal antenna. You have no choice but to install the external one.
Hope this helps.
Jan 27, 2011 | Furuno GP32 GPS Receiver
How many pins on the furuno 1650F?
Sep 07, 2010 | Furuno 1650wf/Nt...
Gps is saying internal battery ng and ng for data back up and all my waypoint are gone and no fix position
There is an internal 3 VDC battery that needs to be replaced in the unit. Any marine electronics repair shop should be able to perform this for minimal cost. We charge $75 for the repair. Please contact me if you need any more help or want to send the unit to me for repair: [email protected]
Feb 25, 2010 | Furuno 1650wf Gps Fish Finder Combo...
Furuno 32 screen full of lines wht we do
The LCD is shot unfortunately and there's not board internally you can swap out. You're going to need to purchase a new one or find a used one.
Jan 24, 2010 | Furuno GP32 Gps 4.5" Display
A furuno 1715 lcd radar was wired to battery backwords
internal damage to the display, fixable by Furuno, and probably economically feasible (guess $250 with round trip to Furuno)
Nov 17, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Data cards for Fununo 1850w
Furuno just stopped producing these models about a year ago. They use a special chart card. You can still purchase the cards from Navionics or C-map if you need to. I will tell you from experience that you should get your internal battery changed out if you havent done so already to keep from losing your settings and waypoints. The dealer will have to save them for you though and put them back on. Furuno made a GP7000 to replace this one and it's uses SDcards and is nothing like the rest of Furuno's product line. The best replacement for this unit is the Garmin GPSMAP 700 series. You can use your old furuno transducer if you have one (with an adapter plug). This garmin unit also has a built in GPS or you can use an external one. The 700 series will be shipped in April. Check out Garmin's website or mid-shore electronics.
Aug 29, 2009 | Furuno 1850w/Nt Gps Chartplotter C Map Nt...
Furuno sounder trandecer problems
the leading edge of the ducer should be higher than the aft portion. The leading edge must not be below the bottom of the transom. To determine if it is turbulence or radiated interference, put the boat in neutral and run motor up in RPM, if it fails then, with boat stationary, then proximity to motor is a problem and you should buy and in-hull ducer. glueing the transom ducer may or may not work well.
Aug 27, 2008 | Furuno GP7000F/NT GPS Receiver
GPS Logo
666 people viewed this question
Top Furuno GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Furuno GPS Expert? Answer questions, earn points and help others
