Cars & Trucks Logo
s
stephen Morris Posted on Jul 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Last time. I have Ford focus 2003 sedan dohc 2L. I lost a part from exhaust system. from back to front I see 1. tail pipe 2. rectangular box shaped part? Lunch Box? 3. missing part Muffler?
I am confused what is Lunch Box? Which is muffler? Which is resonator? Am I missing Muffler?
Russ Hill
Level 3:
  • Ford Master 4,057 Answers
  • Posted on Jul 02, 2017
 Russ Hill
Ford Master
Level 3:
Answers
4057
Questions
10
Helped
1176460
Points
12696
Center box is sometimes called the lunch box, rear box is called back box or muffler. front down pipe box is the cat, catalytic converter.
Wade Cook
Level 1:
  • Contributor 6 Answers
Wade Cook
Contributor
Level 1:
Answers
6
Questions
0
Helped
2265
Points
18
Starting from the front, coming off the exhaust manifold should have, 1. Exhaust pipe, 2. Catalytic converter, 3. Exhaust pipe, 4. Resonator, 5. Tail pipe. Also, there should be an Oxygen sensor somewhere around the catalytic converter.
2answers
Location of catalytic converter 2.3 zetec engine in a 2003 Ford focus zx3
The catalytic converter is the first bulbous box past the exhaust manifold.
2003 Ford Focus: The catalytic converter needs to be ...
JustAnswer https://www.justanswer.com > Ford Repair
Jun 1, 2009 - I have seen a catalytic converter only (no pipes), a catalytic converter with a pipe that bolts onto the manifold? and other variations. Which ...
1 answer · Top answer: Hi, Ok, you have one converter, which bolts to the end of the exhaust [/topics-exhaust-ford/] ...
I have a 2003 Ford Focus ZX3, my engine light has been on ...
Feb 16, 2011
Codes p0420 and 0131 2012 Ford focus. I did and ur went off
Oct 25, 2019
I have a 2003 Ford Focus SE, manual, with over - JustAnswer
Sep 18, 2012
More results from www.justanswer.com
It looks like this
https://www.carparts.com/catalytic-converter/ford/focus/2003
Have 2003 ford focus dohc. part of exhaust system fell off. from back to front I have 1. tail pipe 2. rectangular box shaped part 3. missing part
I see a visit to a muffler shop in your future. Find an independent privately owned shop, not a chain operated place. They'll be better and cheaper than a chain shop
2008 Ford Focus exhaust system noise
Take it to an independent (not a chain) muffler shop and have it replaced. I'm guessing around $200. Also, have the engine mounts checked. If they're worn, the engine rocks too much and breaks the flex pipe.
2003 ford focus catalytic converter location
SECTION 309-00: Exhaust System 2003 Focus Workshop Manual DESCRIPTION AND OPERATION Procedure revision date: 01/24/2003 Exhaust System adobe.gif Printable View (214 KB) Vehicles with 2.0L Zetec-E enginee0008758.gif
Item Part Number Description 1 - Bracket 2 - Gasket 3 - Catalytic converter 4 - Bracket 5 - Gasket 6 - Front muffler 7 - Rear muffler 8 - Hanger 9 - Flexible pipe
Item Part Number Description 1 - Gasket 2 - Catalytic converter 3 - Bracket 4 - Gasket 5 - Front muffler 6 - Rear muffler 7 - Hanger 8 - Bracket 9 - Flexible pipe
Item Part Number Description 1 5G232 Catalytic converter 2 5K222 Mounting bracket 3 5K282 Head shield 4 9451 Gasket 5 5A262 Insulator 6 5E292 Converter and muffler assembly 7 9448 Gasket 8 5G203 Flex Pipe NOTE: The exhaust systems shown in this section are production systems.
The exhaust systems are of a two-piece construction for production and five-piece construction for service.
Catalytic Converter
The catalytic converter fitted to the Focus range resembles a small muffler. Because of the high temperatures at which the catalytic converter operates, the vehicle body areas around the catalytic converter are protected by heat shields. The catalytic converter controls three emissions; Hydro carbons (HC), carbon monoxide (CO) and oxides of nitrogen (NOx).
Catalyst deactivation due to poisoning
Sulphur (S) in the fuel can cause deactivation of the catalyst.
Lead (Pb) in fuel can cause a severe deactivation at levels above 5 mg per liter of fuel. It is therefore essential that vehicles with catalytic converters always operate on unleaded fuel.
Zinc (Zn) and phosphorus (P) present in some oils, can cause deactivation if oil consumption is high.
The effect of sulphur is felt most if it is released from the catalytic converter as hydrogen sulphide (H2S). This has an unpleasant odor similar to rotten eggs. Changing the fuel manufacturer may help in reducing this phenomena.
To minimize H2S emissions, it is essential that the idle CO level is within specification and that the engine emission system is functioning correctly. For additional information, refer to Section 303-08A or Section 303-08B.
ani_caut.gif CAUTION: If temperatures exceeding 900°C are achieved the catalyst substrates will start to deteriorate. It is important that the cause is defined and rectified if subsequent melts are to be prevented.
Catalyst melts are normally accompanied by loss of power due to excessive back pressure. For additional information, refer to Section 303-07A or Section 303-07B.
High substrate temperatures are caused by the ignition or the fuel systems. For additional information, refer to Section 303-07A or Section 303-07B.
Misfires at high engine speed may result in an almost instantaneous melt.
2010&c18=modelyear&c20=n720709&c35=wsm%2cexhaust%20system%2cs3y%2c309-00%2cdescription%20and%20operation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=405&ct=lan&hp=n&[aqe]
7helpful
2answers
O2 sensor location for 2002 Ford Focus Sedan . Have replaced 1 of the O2 sensors in the engine carpartment but won't reset and I also understand there are 2 other O2 sensors that maybe causing them to not...
to make you clear where does the oxygen sensors where is........... some have four, three or two, all O2 SENSORS ARE LOCATED AT EXHAUST PIPE. before and after catalytic converter,
2answers
How do you replace the tail light in a 2003 Ford Focus ZTS sedan? not a hatchback
Open up hatch , reach in and pull back liner, Remove nuts to release light lens. then push, turn and pull out bulb socket and same for bulb.
3helpful
2answers
My radio and cd player or lighter doesnt work. but my clock does.....what is wrong!
Change out your ACC Relay. It is located on drivers side behind kick panel in fuse box. It is Black and rectangular shaped. Check for moisture. Many times water comes off driver door Chanel right into fuse box. Open driver door look for holes in front panel. ACC Relay is under 10 bucks at auto parts store.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
