Question about LG Televison & Video
I have an LG sound bar,there is a lag between the tv and the sound bar voices,the tv voices will go silent for several seconds and then the sound bar kicks in ,how can I fix this
Posted by Dona Bagan on
Steve P
  • LG Master
  • 3,712 Answers
Mine was the same way,, I had to go to Best Buy and ask how to fix it,,,The sound sync is not set at zero...
http://www.lg.com/us/support/manuals-documents
Posted on Jul 05, 2017
4 Related Answers
Anonymous
  • 58 Answers
SOURCE: LG Chocolate, De-activate Voice Mail?
There isn't a way to disable voicemail cause it automatically fowards the call.
Posted on Jan 11, 2009
Shailesh Parikh
  • 83 Answers
SOURCE: My Samsung HCM422W TV has a sound problem, all
check your tv set sound system PAL/BG NTSC/DK
SCAEM/ I NTSC/MN PLS check your country colour and sound system set on your tv .
if not
then probum is in the pcb cheked sound cristal replase and sound is ok.
Posted on Oct 04, 2009
Peter Schr?der
  • 241 Answers
SOURCE: I have just brought a
I had the same issue with a Samsung 1580 BD player. Stopping the movie ans starting it again could sometimes solve the problem for a little while. The problem only occured when using bitstream sound. Switching to PCM never showed the problem. The player was faulty and was replaced by the shop.
Posted on Jul 18, 2011
SOURCE: I have a LG 55" smart TV and can not get the sound
get into your setting on your tv (menu) and click on the audio and make sure the speakers are in off position.
Posted on Dec 04, 2011
I have a Boston acoustics model 120. The sound lags by about a half second from the tv. How do I adjust this lag so that I get real time audio?
run the sound directly from the tv, sounds like you are running it from another source , which is way the sound lags behind the picture. From the little info you have given, thats what i would say is the problem
Sep 06, 2014 | Audio Players & Recorders
Lags on PS3 LG LE750
if you think the problem is not from your PS3 then i suggest you connect with another TV and see if it works properly
Jan 03, 2014 | Video Game Consoles & Games
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
I have just brought a Samsung SMART TV and a Samsung BluRay player and we are experiencing audio lag when it plays some BluRay dvd's. The lag is quite severe (3-5 secs) on some dvd's. How can this...
Jul 18, 2011 | Televison & Video
My phone is on silent still
you have to go to "voice commands" and turn off the call alert mode... put it on "ring only"
Sep 29, 2009 | LG Xenon GR500 Cell Phone
I can't turn off the keypad tones on a LG Xenon phone
To turn off the beep on the keypad beep or voice on an LG Xenon, go to menu; settings; sound; volume. From there you can raise or lower the volume or mute the keypad and other sounds.
May 25, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
Sound and mouth are not together
I'll suppose you are using a external cable receiver.
If so, please try another input on your TV set.
Cheers,
Gerard
Jan 27, 2009 | LG 42LC2D 42 in. LCD HDTV
LG 42PC5D Sound Lag
Turn the volume on the TV all the way down. Its becasuse you have the sound come from both sources. its kinda fun to play with.
Sep 24, 2007 | LG 42PC5D Television
Televison & Video Logo
258 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
