Question about Pioneer Car Audio & Video
Pioneer DEH-P4100 volume is noticeably lower when listening to the radio. Volume normal listening to CD, Aux and USB. Small external amp controlling sub but that shouldn't affect tuner. What ya think?
Posted by Alan Hart on
richie46
    Top Expert:
  • Pioneer Master
  • 12,962 Answers
The tuner feed is at lower level than other sources. Happens. Unit may have a control for this internally and you might want to check it out with manufacturer of unit.
Posted on Jul 02, 2017
The volume is noticeably lower when listening to the radio. It sounds normal on CD, Aux and MP3. I know it has a built in amp. Could this be the issue. Thanks.
You have not mentioned what type of radio you have, what car it's installed in, and what other audio equipment you have. I will assume it's an aftermarket radio, and it's common that the tuner's signal strength is not going to be as powerful as the other sources. If the built in amp is used, then it's used all the time, with all sources, including the tuner. Some brands will have a loudness offset function wherein you can lower the power output of the CD/Aux/MP3 inputs to volume match the radio, but there's no fun in that. There's not a way to make the tuner play louder, unfortunately, aside from adjusting the volume when using the tuner section. Technology has brought many advances, including a much higher signal to noise ratio, which is why digital trumps analog in this instance. This is what you are experiencing, which is not necessarily a technical issue, but a technology issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jul 02, 2017 | Car Audio & Video
What could be causing a loud popping when volume is raised past a certain point?
This is normally cuased when customers rely on small amp in any radio instead of an aftermarket amp. If your radio starts to clip wither lower to normal listening volume or invest in a aftermarket amp to amplify sound.
May 19, 2014 | JVC KD-G230 CD Player
I am unable to reset my pioneer deh p4100. I see
remove the unit and disconnect the battery+red and yellow cables.check the front unit for derfomed plastics or stucked somehow microswitches!someone stucked from the heat!
Jun 05, 2010 | Pioneer DEH-P4100
Everything has froze... I'm stuck listening to a cd over and over... I can't change the volume, I can't skip a song, nothing... pioneer deh-p4100
try pressing the reset switch. should be a pencil tip sized hole on either the face or the subpanel. barring that you can try disconnecting power to the radio for a few minutes.
Apr 28, 2010 | Pioneer DEH-P4100
Aux in runs only back speakers and no volume control
This also happened to me, I just replaced the cable and works fine now.
May 27, 2009 | Pioneer DEH-P3000 CD Player
"Down volume" button on Pioneer head unit in my '05 Scion broken
I had a similar problem with one of the cursor type keys - I ended up taking the face apart (4 small screws on the back then gently prise apart) & discovered the small pin attached to the back of the button which presses the internal switch had slipped off the pad, it took a couple off attempts to put it back together again but once it was re-assembled it was fine, just be careful not to lose anything! ;)
May 12, 2009 | Pioneer DEH-P4100
check sub setting some radios can select between non fading sub output or aux input
May 08, 2009 | Pioneer DEH-P3000 CD Player
Pioneer DEH P4100 Volume Stuck
if all you need to do is get the cd out there is a small hole in the foront of the unit just big enoufe for a papper clip just stratien one out and put it in the hole but if you want to fix your unit then you will have to take the face plate apart get the soda out of the face plate i always use glass cleaner and cotton swabs for this just make shure you get any and all residue off before you put it back togethr and make shure you clean the rubber pads under the buttons and you should be good to go
Oct 09, 2008 | Pioneer DEH-P4100
Aux port
Turn off Radio with car on or key on. Press and hold the big volume button in for 3 seconds, and the radio will say initialise. Than press the FCN button till it says AUX. Than press the SEL button till it says "Aux ON ". Turn on radio and you should be good to go.
Aug 29, 2008 | Pioneer DEH-P4800MP CD Player
Wire Color Code
what color is what on the pioneer deh-p4100
Jul 12, 2007 | Pioneer DEH-P4100
Car Audio & Video Logo
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
