Question about Car Audio & Video
You have not mentioned what type of radio you have, what car it's installed in, and what other audio equipment you have. I will assume it's an aftermarket radio, and it's common that the tuner's signal strength is not going to be as powerful as the other sources. If the built in amp is used, then it's used all the time, with all sources, including the tuner. Some brands will have a loudness offset function wherein you can lower the power output of the CD/Aux/MP3 inputs to volume match the radio, but there's no fun in that. There's not a way to make the tuner play louder, unfortunately, aside from adjusting the volume when using the tuner section. Technology has brought many advances, including a much higher signal to noise ratio, which is why digital trumps analog in this instance. This is what you are experiencing, which is not necessarily a technical issue, but a technology issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Posted on Jul 08, 2017
SOURCE: Logitech g51
I'm sure you went to Control Panel, opened device manager, and and checkeck for any yellow
checks for your
sound, video and game
controllers. If there are none, your system is go. Then go to your
audio manager on control panel, and set it up for whatever speaker
configuration you have. I have realtec audio manager. This step is a
must for configuring—you choose whether your laptop will use its
own speaks or use your external speakers—you have to turn off the
internal speakers and turn on the external. Did you forget?
Posted on Mar 10, 2008
SOURCE: How do I connect an mp3 to my 2008 sonata?
The 2008 Sonata does not come equipped to plug in a separate MP3 player. The MP3 on the face of the radio/CD player refers to the fact that the CD player will play MP3 files. If you want to play from a separate player, you will have to add an FM modulator or something similar.
Posted on May 09, 2009
SOURCE: 2008 Hyundai Tiburon GS Sat Radio ( Want Aux in it )
Here is a link for instructions. Copy and paste to browser
http://www.installer.com/pdf/99-7313.pdf
Posted on Jun 04, 2009
SOURCE: can I use the Aux port to play USB in Ford audio/CD MP3 player
hi, you may use the aux port by using the right type of usb, hope this helps
Posted on Feb 12, 2010
SOURCE: Nissan Almera Tino 2004 - built-in radio is quiet or screeches
with the proper wire harness you can retrofit any aftermarket indash you want call any car audio shop they will be happy to set you up with exactly what you need
Posted on Mar 17, 2010
Testimonial: "great thanks"
Jul 02, 2017 | Pioneer Car Audio & Video
May 19, 2014 | JVC KD-G230 CD Player
Sep 24, 2012 | Philips FWC527 CD Shelf System
Jul 11, 2017 | Pioneer VSX-818V-K Receiver
Oct 31, 2009 | SanDisk Sansa Fuse MP3 Player
May 21, 2009 | Pioneer DEH-P6300 CD Player
Jan 27, 2009 | Jensen CD2610 CD Player
Jun 17, 2008 | Blaupunkt Car Audio & Video
Sep 23, 2007 | GPX HM3817DT Shelf System
Sep 22, 2007 | Car Audio & Video
62 people viewed this question
