Hey Hunter,
First, make sure the manual release screw is seated tight.(port side of engine mount) ..Does the pump run and just not lift? Does the motor jump and jerk while you are trying to trim up? Can you lift the engine by hand while you are trimming? Have you filled the fluid reservoir with fluid? - There is a cap with a slot on the reservoir - MAKE SURE the engine if at full tilt - fill the reservoir.. you can use Dexron type III transmission fluid.... check these items and reply to me.
