Dishwashers Logo
Question about Fisher Dishwashers
F1 showing on display of Fisher & Paykel DW920
Posted by Gail Thompson on
5 Related Answers
yalmer
Hjalmer Lamminen
  • 552 Answers
SOURCE: Display frozen
I think if you push the heated wash and heated dry buttom several times until all the buttoms light up this may fix your problem.
You may have different kind of light flashing indicator, but the same solution.
Possibly check the sequence switch
Posted on Feb 09, 2008
Anonymous
  • 784 Answers
SOURCE: F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Posted on Jul 03, 2009
Anonymous
  • 8619 Answers
SOURCE: Have a fisher paykel dw920
Hi
Thanks for using FixYa. You are right
F1 error means that the flood switch has been activated. You’ll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Aug 22, 2010
Anonymous
  • 8619 Answers
SOURCE: How do i reset a
Hi
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 07, 2010
James Foster
  • 251 Answers
SOURCE: fisher and paykel nautilus dw920 Need
Hi - here are the instructions to help with your project
1. Isolate from power.
2. To remove the outer door panel, remove the eight screws securing it to the inner door panel. Be careful of sharp edges.
3. To remove the handle, remove the six torx drive screws securing it through the inner door panel.
4. Refit in reverse manner.
Note: 230 volts is still present at the detergent dispenser and electronic P.C.B. unless power is isolated at the plug outlet or mains.
Location: The door handle latch is located within the centre of the handle moulding
and is retained by a pivot latch. The microswitch is situated on the side of
the latch and is clipped in.
After isolating the machine from the power supply:
1. Remove outer door and handle (refer Section 6.2).
2. Remove the latch by sliding it away from the P.C.B. console.
3. Unclip the microswitch from the latch.
4. Ensure the springs and microswitch lever are fitted to the latch when re-assembling.
Refitting: Refit in reverse manner.
Sorry I cannot provide a sketch for public view, I may get into trouble.
Cheers
Posted on Jul 07, 2011
Testimonial: "Not at all helpful"
4helpful
Fisher & paykel fault "F1" is displayed on the top
hello
F1 means the flood sensor senses water at base of machine at PC board.
You need to take out bottom drawer and check for water puddle under where the drawer was.If there is water you can get the machine going again by comletely drying it out(F1WILL CLEAR),but it still means you have a leak.With bottom drawer out you can really see whats going on.Once F1 is clear you can actually run upper drawer and see if it leaks.Most likely culprit are the lid actuators.Replace all 4 . It'll run like new.Don't overload drawer .That can cause lid leak too.Also the PC board may be damaged and may start to go crazy giving fake F1 codes.$80 easy fix.
good luck
10helpful
I have a two drawer Fisher and Paykel dishwasher. The lower drawer initially displayed an F1 and now shows nothing. It does not currently display a message even after starting it. It does not appear to...
This is a flood error code. The bottom drawer needs to be removed to dry up the water. The video below explains how to do this. It's actually pretty easy.
1helpful
2answers
Have Fisher and paykel Nautilus dishwasher showing F1 fault - what does this mean? Dishwasher was leaking water all over the floor dont think major problem as it starting draining when power was reset
f1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
1helpful
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
2helpful
2answers
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
10helpful
My dishwasher keeps flashing F1 error message
The f1 code is caused moisture in the electronics part most likely in the door.see if there is any way that you can see where moisture might get in and plug that spot up. In the case of the f1 code when not using the dishwasher leave the door propped open to help dry out the electronics.
Top Fisher Dishwashers Experts
vince
Paul
NOEL
NOEL
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
