The shorter tube goes to the inlet siphon side of the purge bulb and connects to the top carburetor fuel port. The longer tube goes from purge bulb outlet to the tank.
To test it is assembled correctly and operational, leave the longer tube disconnected at the tank and press the bulb repeatedly. Fuel should draw from the tank, through the carb, into bulb, and expelled out the longer tube (fuel return).
It's best to replace fuel filter and leave the longer return line disconnected until after above test.
has anybody fornd an answer to this ? I put in a route, but I am no longer able to cancel it. The spot button is no longer displaying and the route stays active.
does the problem occur while watching dvds. it is possible that it is an issue with your tv but i would try switching off of cable to a game console or dvd before i said for sure it was the tv. you also might try using another port on your tv such as hdmi, s video, rca or componet ports . if any of those ports work i would replace my cable from the cable outlet.
if you are installing a secondhand gas cooker then you need the manufacturers instructions you need to be a gas engineer and if the parts are no longer available you should get a new unit
