Most of the times the fuses on cub cadets are located under the engine cowling close to where the steering shaft runs through the frame near the battery. Follow the wiring harness from behind the ignition switch and it should lead you to the fuses. There are no very many fuses to check on your mower. Good luck and I hope this helps.
Check the connector and wires at the pto clutch. Sometime the movement will create a cut in the wiring you may be able to see. If so if the wire touches ground it will blow the fuse and if the wires touch each other it will short. if the short is not there then the clutch is bad?
