There is safe mode dialog on bottom left of my phone screen, when i try to remove it by following the disable safe mode it keeps coming bag even though the pone has been restarted
SOURCE: Apple iphone shows on screen ''Phone Disabled connect to itune''
did you try to use itunes to restore it to its factory settings?
SOURCE: How to remove BIOS memory cache
Since it is a Toshiba Tecra if you are not worried about losing data on the laptop you can try turning on the laptop and start pressing the zero key. It should give you the option to restore your laptop if you haven't deleted the restore partition on the laptop.
SOURCE: STOP: 0x00000034 blue screen error...
This is a cache manager error or a missing DLL file error. This might have heppend as a result of some hardware of software changes that you might have made recently. You can either install the removed drivers once again or need to run a repair reinstall of windows to get the curropt dll files working again.
http://www.jj54.com/Fix-Error-Number/0x0000/
Please let me know if this does not help else please accept it.
Thank You for contacting Fixya.com
SOURCE: My hone got wet and i imeadiately removed the
i droped y samsung intesity in water a few weeks ago. it was able to call out but now the screen will only blink the verizon logo and at the moment it says useb download mode. Is there anyways that i can recover my data form the phone?
Turn on the computer and begin hitting the "F8" key when you see the BIOS screen.
This will take you to the Safe Mode menu.
Use the arrow keys to highlight "Safe Mode," then hit "Enter" on your keyboard.
This will boot your computer in Safe Mode, a minimalist manner of operating Windows that runs only essential Windows files.
If using Windows XP in Safe Mode, click the "Start" button and then click "Run." In the box that pops up, type "msconfig" and hit "Enter."
If using Windows Vista or Windows 7, click the Windows logo in the bottom left corner of the screen, type "msconfig" in the search field and then hit "Enter."
This will open the System Configuration Utility.
In the System Configuration Utility box, click the "Services" tab, check the box that reads, "Hide All Microsoft Services," click "Disable All" and then click "Apply."
In the System Configuration Utility box, click the "Startup" tab, click "Disable All" and then click "Apply." Next, click the "Close" box.
A box will pop up that prompts you to restart your computer.
Select "Restart" and let the computer restart itself, allowing it to boot to Windows normally.
If the computer still stalls when trying to boot to Windows, restart the computer and boot to Safe Mode again.
Run your antivirus program in Safe Mode, deleting any files that are flagged as viruses, spyware or malware. Restart the computer and boot to Windows normally
hope this helps
