When plugged in to charge, green light stays on. When unplugged, nothing works. When plugged into computer, "defective" appears on computer screen. What should I do now?
SOURCE: Dell latitude D600 battery charge light flashing
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
SOURCE: Will not charge, or turn on
Probably the plug on the navman has suffered what we call dry solder joints from inserting and pulling out the charger you need a tech to fix it. soldering is nesessary shouldnt be too expensive I fixed mine its about half an hours work if not too damaged inside
SOURCE: Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill
blow a power supply. The problem is caused by parts calledcapacitors
overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou
can take the back cover off your monitor and look for the bad
parts,replace any that look like the pictues and your monitor should
workfine. The capacitors do need to be installed with the correct + and
-connections, note the stripe on the old one and insert the new one
thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
SOURCE: Sharp Aquos LC42D62U with blank black screen, good
Unfortunately not really, it is the video board of the LCD that has failed, it is a major repair to say the least. You can check with a local repair shop to estimate the repair, but it will be spendy :(. I'm so sorry about the bad news there, but that's definitely what it is. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
Thanks
Tim
Take it back for warranty.
