Question about HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Series (chassis bottom)319470-001 (319470001) CD-ROM Drive
Redeye It turns on but screen isn't on, and making a beep noise.
Posted by jvsl on
  • Rendie Mar 19, 2008
    My Compaq Presario 2500 has been doing the continuous beeping at boot up. My power button is/has been stuck (for awhile) and the only way I can turn it on is by using the quick hit buttons. I think these buttons might be sticking too. During the beeping the screen shows a long row of verticle lines (maybe a quarter inch high), the lines start to fill in like something is being loaded then the beeping stops and the computer continues to boot up with no other hitch. Once the computer boots up the beeping goes away. I wasn't sure if the sticky buttons had anything to do with the repetitive beeping or if there is something more serious happening. Does anyone have a clue? I haven't taken it anywhere yet to have it looked at.
    Thanks
  • Anonymous May 11, 2010
    how many beeps and are they short or long? also what is the model number?
Anonymous
Contuns beep
Posted on Mar 16, 2008
Beeping sound
Make sure screens for water hoses and water valve aren’t obstructed with debris. Make sure drain pump isn’t obstructed
Oct 15, 2018 | Washing Machines
My laptop makes loud beeping noise and screen comes up all fuzzy & crazy
sounds like hard drive is bad, replace with new or buy new computer
Jan 09, 2013 | Acer Aspire Computers & Internet
Beeping noise
Ok if you can restart computer,,,when it first starts turning on,,hit f1,,will bring you up to a menu,,may can find prob listed there,,also beeping noise usally video related ,,ddr cards,,open side od computer,,turn it off,,,you will see what looks like cards in a row,,,ddr cards,,pull one out,,,restart,,see iff resolved,,if not repeat,,put it back ,,remove ther,,and so on,,could be bad ddr /ram card,,also hp .com support ,,they can help,,,they have a killer support page,,very helpful,,goodluck
Dec 20, 2011 | HP Computers & Internet
When i turn on my laptop it makes a beeping noise for about 15 seconds.the screen also goes black after this for about the same time.then the laptop works fine just wondering what may be the cause of this.
Hi there, I am also facing same problem with my Dell Inspiron mini 1012, when i turn on my laptop it makes a beeping noise for about 15 seconds.the screen also goes black after this for about the same time.then the laptop works fine just wondering what may be the cause of this. S Bhat, India
Nov 01, 2010 | Computers & Internet
Computer makes beeping noise
The beeping is telling you something ... counting the beeps and matching that to the make and model on a beep decoder would answer your question.
What are you going to do about the switch controlled outlet? Id suggest you run a power strip from another hot all the time outlet. It is a death sentence to continue to shut your computer off with first warning it.
I hope this helps you
a
Sep 30, 2009 | Computers & Internet
Turning on my gateway 510 x PC I get a black screen/white cursor
Did you make any changes recently (add memory, etc.)? Does it make any beeping noises on startup? I've had this problem occur when putting in the wrong type of memory. If you haven't added memory and there is beeping on startup, find the manufacturer of the MOBO and you should be able to find a beep startup code to tell you what the issue is.
Apr 13, 2009 | Gateway 510 X (10272197) PC Desktop
My Big Screen making a loud beeping noise!
The beeping noise is usually related to the Horizontal out put transistor or flyback being faulty or one of the coils are loose near the flyback. If you remove the rear cover without touching anything can you tell if the beeping is coming from the large transformer with the red wire coming out of the top or is it coming from a black transistor on a aluminum heat sink.
Jul 22, 2008 | RCA P52930BL 52" Rear Projection...
Turning af beam off
The same lamp used for AF is also used as a preflash for redeye reduction. Turn off redeye reduction as well as AF assist.
Apr 21, 2008 | Canon PowerShot A520 Digital Camera
Redeye
Red-eye is actually caused by the light from the flash bouncing off the back of the retina and picking up the color red from the blood vessels. To correct this effect, follow these steps: Turn the mode dial to PlayBack Mode (green arrow) and display the image with redeye. Press OK\Menu button. Using the arrow pad, navigate to MODE MENU>EDIT>REDEYE FIX. Press the right arrow key, START will display. Press OK\Menu After {BUSY} bar displays, a screen will display with an option to cancel or save the image. ? If the option [Go] is displayed, press the OK\Menu button. This saves a corrected version of the image. ? If the option CANCEL is displayed, than the camera was unable to correct the image. Press the left arrow key to exit. This correction may not work on all pictures. If you import the original image into Olympus Master software you can also apply the Red-Eye fix located in the Edit menu. This lets you precisely pinpoint the eye area and remove the red. It even lets you remove green or blue, which can occur with animals.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Redeye
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Computers & Internet Logo
96 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
