Question about Boston Acoustics Audio Players & Recorders
My Boston acoustics sound wave digital cinema remote control is not working, changed battery, can't use the system at all without it, my tv remote unpaired itself apparently. Do I need a new one?
Posted by Amy Curtiss on
  • Hector C Hernandez Oct 19, 2018
    You can buy a substitute remote control in eBay or Amazon.com
Hector C Hernandez
    Habit-Forming:
  • 8 Answers
Posted on Oct 19, 2018
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: onkyo SR605 Remote not working at all.
Dear Bzambo,
The batteries on the remote are fresh? if so the remote might be bad.
Sidlahora
Posted on Dec 06, 2007
Anonymous
  • 279 Answers
SOURCE: adapting Boston Acoustics BA7800 for use with TV
Here's what you need:
http://www.vpi.us/cable-audio.html
Scroll down to the 3.5mm Stereo Jack / RCA Plug x 2 Y-Cable
Converts your TRS connectors to dual RCA plugs. You said you have 3 TRS connectors. Does the TV have 3 sets of RCA plugs you can use with this? If not, you may not be able to get full surround sound, just stereo sound, from your TV - and you'll need some RCA splitters to plug two (or three) cables into one port. I know you can get those at Radio Shack.
-Dyllan
Posted on Jan 09, 2008
Anonymous
SOURCE: how to hook up a boston acoustic ba7500g speaker
you can connect the BA7500G speakers to a regular digital coaxial output by using a cable that has an RCA plug on one end and a stereo minijack on the other. However, the pole of the RCA must connect to the tip of the stereo minijack and the shield of the RCA must connect to the middle ring on the stereo minijack. Also set your soundcard to output at 16bit and 48khz.
Posted on Dec 05, 2008
Anonymous
  • 7 Answers
SOURCE: Boston Acoustics BA7500... Problem
Try installing an old creative driver for digital audio but use system restore to take a backup of your settings first. Also, you may have to update the bios and unselect the AUTO mode for sound.
Posted on Feb 23, 2009
issikiki
Naajiyah Auladin
  • 563 Answers
SOURCE: My remote control stopped operating my Boston
You can contact the BA. As they will make arrangement to take it back and replace it. BA is a good company and they give consumer feedback as soon as possible. Well, only if you haven't got an answer to your question.
Posted on Jan 26, 2010
Boston Acoustics TVEE 26 factory reset
Reprogram the remote to function with a different brand of equipment that you do not have. The remote can't affect the receiver if it is not talking to it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Feb 23, 2014 | Boston Acoustics TVee Model 26
Lost remote control for bose wave model number AWRCC1 will the additional bose acoustic wave music system remote control work
Check this site to get setup codes and model number of a suited universal remote control. It has many details you want. Check this site too.
Apr 21, 2013 | Bose Wave radio remote control - Graphite...
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
My speaker set up boston acoustics ba7500 will'nt
The Guys at Boston Acoustics helped me get my speakers to work. The Boston BA7500 speakers are coaxial digital speakers so you need a digital output on your sound card. Analog will NOT work. My new HP Pavilion has a Realtek sound card with a digitial RCA plug output. I had to go to Amazon and get a male RCA to 1/8" Stereo Mini Female adapter plug. I just pluged it in and configured my sound card to 16 bit 48 khz output to the RCA output and everything works great. The speakers sound better then ever, great for 10 year old speakers! They sound better then anything I have seen avalable today. The guys at Boston were the only guys that helped with getting this to work! Thanks again to them and Amazon has every type of adapter plug you may need. Good luck.
Rick
Oct 08, 2009 | Boston Acoustics BA7500 Computer Speakers
What type of battery goes in the remote for a BOSE wave music system
We have a Bose Acoustic Wave Audio System II, and our remote uses nickel metal-hydride batteries CR2032.
Sep 29, 2009 | Bose Wave music system large Remote...
Boston Acoustic BA735 no sound on new hp computer
All you need to do is download and install the Vista drivers from Boston Acoustic. You should then be all set. Hope this helps.
Sep 06, 2009 | Boston Acoustics BA735 Computer Speakers
What batteries doe the bose wave music remote needs
We have a Bose Acoustic Wave Audio System II, and our remote uses a nickel-metal hydride battery CR2032.
Aug 31, 2009 | Bose Wave music system large Remote...
Trouble with rear speakers
This may be a software issue. If you only had two speakers before, the software will not use the rear speakers.
Go to Control Panel. Click on "Sound and Audio Devices". Under the Volume Tab, at the bottom, you will see a picture roughly representing the type of speakers.
Click on the Advanced button.
Click on the arrow in the pick box, and choose Surround Speakrs or the 5.1 Speakers.
Click Okay. Try the speakers again.
Apr 06, 2009 | Boston Acoustics (BA7800) Computer...
Suround sound dvd
Get a Boston Acoustics Tvee Soundbar System.
Dec 06, 2007 | Boston Acoustics TVee Model Two TV...
192 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Harrie
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
