Has UE code even without a load inside. Does sometimes finish with laundry but often doesn't. I hear that software update is step 1 to resolution, and would like to save service fee
There is a software update to fix this issue where the washer is too sensitive to unbalance and keeps trying to rebalance a lot even when there is no load. Only LG can do the update. Call them.
Check to be sure the machine is level and that all four feet are touching the floor. Tighten the locking nuts on the feet to lock them into place. If that doesn't seem to be the problem, either the suspension rods or shock absorbers may be broken or worn out.
SOURCE: kenmore washer just stopped
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, check/replace lid switch. Also try tightening the lid hinge screws on the left side. if these screws come loose, the machine will not operate
SOURCE: "UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
Try adjusting the load size, and make sure the unit is level.
SOURCE: LG front load washer coded UE. what does that
UE means unbalanced error. when you see this, it means the clothes are unevenly distributed in washer, it's basically unbalanced.
SOURCE: WM1814CW Front Load Washer: UE error code on display...
UE is Imbalance error..Redistribute the load or you may have tried to wash something which will not 'spread' enough to balance the load...Nomess
SOURCE: LG washer Model # WM1814CW problem code UE
UE=Imbalance error
load too small
appliance tilted
laundry clumped to one side
non distributable object in tub
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
